Console problem update
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Nov 5 19:56:33 UTC 2004
Etienne Fortin wrote:
> Tadam!!!!!
> I'm FINALLY getting somewhere!
> It was now hanging on packet number 13... 13... Hmmm.... Looks like the
> CR character. And where does it was throwing an error? In the
> packet_number/comp_packet_number test. It appears that whatever a 13 was
> encountered, termios was creating a matching 10, f***g up my data!
> Ok now there's still some work to do, but it seems to start to look like
> something.
That sounds like you have CR/LF expansion on. Are you sure
you have the termios settings for NO canonical processing
turned on?
> Oh my, where would I be without open source RTEMS! :)
It is really nice to be able to trace through every line of code
on a piece of target hardware.
--joel
> Etienne
> -----Message d'origine-----
> De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> Envoyé : 5 novembre, 2004 14:29
> À : Etienne Fortin
> Objet : RE : RE : RE : RE : RE : RE : RE : Console problem update
> Etienne,
> first thing first: If head is "behind" tail, if is
> still beyond, but has reached the physical end of
> the ring buffer and therefore started over at the
> beginning (its a ring...).
> Second: I suspect my code snipplet some days ago is
> not sufficent for your port :-(((
> Your "c_iflag" selects XON/XOFF flow control for the
> output. I don't think this is a good idea.
> And your c_oflag has MANY bits set, which really
> doesn't make sense. did you miss a "&" in a
> expression like:
> c_oflag &= ~(OPOST|.....)
> Look into a termios man page and clear all the
> c_oflag options you don't need. I would even guess
> (oh no, not again!) that c_oflag=0 would be nice for
> you...
> Hm, maybe this makes things a bit better...
> wkr,
> Thomas.,
>>Hi Thomas,
>>Thanks again for your help.
>>And no, I really don't think that termios is the problem. To the
>>contrary, it looks like a well proven design that worked for all of
>>you.
>>But, the problem is really nasty, like you said, and there's so much
>>possibility regarding the cause of all this!
>>An update:
>>With HW flow control (driving RTS only and don't care for CTS since
>>it's not correctly routed on the m5282lite from Axiom), I don't get
>>any more buffer overrun. But, it continue to hang after about 12k (8k
>>for another file, probably something else with another) with the
>>following values in
>>rtems_termios_tty:
>>$2 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
>>= 436273159, osem = 436273160, cbuf = 0x80d537e4 "", ccount = 0,
>>cindex = 0, column = 0, read_start_column = 0, termios = {c_iflag =
>>8450, c_oflag = 4294967230, c_cflag = 2147485885, c_lflag = 32768,
>>c_line = 0 '\0', c_cc =
>>"\003\034\177\025\004\n\001\000\021\023\032\000\022\017\027\026\000\00
>>0"
>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c
>>"\001\220\020\001\001\037c\002\001Ä\204", Head = 840, Tail = 1203,
> Size
>>= 2048, Semaphore = 436273162}, rawInBufSemaphoreOptions = 0,
>>rawInBufSemaphoreTimeout = 100, rawInBufSemaphoreFirstTimeout = 0,
>>rawInBufDropped = 0, rawOutBuf = {theBuf = 0x80d53870 "\n\nC3D 1.0.0
>>File Tranfer Test\nNeed a valid FAT12 file system on /dev/nvram0 (run
>>fs_create).\n\nMount DOSFS file system on /dev/nvram0 (run fs_create
>>before)\nfsmount: mounting of \"/dev/nvram0\" to \"/mnt/"..., Head =
>>395, Tail = 395, Size = 1024, Semaphore = 436273161}, t_dqlen = 0,
>>rawOutBufState = rob_idle, device = {firstOpen = 0x17ec
>><console_first_open>, lastClose = 0x1848 <console_last_close>,
> pollRead
>>= 0, write = 0x1722 <console_interrupt_write>, setAttributes = 0x1772
>><console_set_attributes>, stopRemoteTx = 0x1794
>><console_stop_remote_tx>, startRemoteTx = 0x17c0
>><console_start_remote_tx>, outputUsesInterrupts = 1}, flow_ctrl = 256,
>>lowwater = 1024, highwater = 1536, rxTaskId = 0, txTaskId = 0, t_line
>>0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0}, tty_rcv = {sw_pfn
>>0, sw_arg = 0x0}, tty_rcvwakeup = 0}
>>As you can see, no data dropped at all (rawInBufDropped == 0). But,
>>Head == 840 && Tail == 1203... What does this mean? There's 1203-840
>>characters in the buffer? Shouldn’t be since you said that Tail < Head
>>means characters in the buffer. So it means there's 1203-840 places
>>available in the buffer?
>>And for a file it hang in the semaphore, for anothers it bump out of
>>my Ymodem code with an error... If you want (I would appreciate but
>>you already put time into this), could you look at the configuration
>>of the termios structure. I suspect something about characters being
>>wrongly interpreted somewhere in the flow of data.
>>Etienne
>>P.S.
>>Another file, same behavior:
>>$3 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
>>= 436273159, osem = 436273160, cbuf = 0x80d537e4 "ò", ccount = 1,
>>cindex = 1, column = 0, read_start_column = 0, termios = {c_iflag =
>>0"
>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c "", Head = 197,
>>Tail = 1223, Size = 2048, Semaphore = 436273162},
>>rawInBufSemaphoreOptions = 0, rawInBufSemaphoreTimeout = 100,
>>rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 0, rawOutBuf =
>>{theBuf = 0x80d53870 "\n\nC3D 1.0.0 File Tranfer Test\nNeed a valid
>>FAT12 file system on /dev/nvram0 (run fs_create).\n\nMount DOSFS file
>>system on /dev/nvram0 (run fs_create before)\nfsmount: mounting of
>>\"/dev/nvram0\" to \"/mnt/"..., Head = 399, Tail = 399, Size = 1024,
>>Semaphore = 436273161}, t_dqlen = 0, rawOutBufState = rob_idle, device
>>{firstOpen = 0x17ec <console_first_open>, lastClose = 0x1848
>><console_last_close>, pollRead = 0, write = 0x1722
>>Envoyé : 5 novembre, 2004 13:41
>>À : Etienne Fortin; rtems-users at rtems.com
>>Cc : rtems-users at rtems.com
>>Objet : RE : RE : RE : RE : RE : RE : Console problem update
>>Etienne,
>>>The sender of a file in YMODEM waits for an ACK to be received
>>>before
>>>sending the next packet. So, I can wait forever (at least a little
>>>less than the timeout value of YMODEM which is, if I'm not mystaken,
>>>about 30
>>>seconds) between each packet.
>>>And I don't understand why you say hardware flow control would not
>>>help. If RTS is negated during transfer because the buffer is about
> to
>>>get filled completely, then the transmitter (sender) will stop and
>>>wait for RTS (its CTS) to get asserted again before continuing. This
>>>would ensure that the input buffer never overflow. Am I
> understanding
>>>correctly or is there something I miss in my comprehension?
>>Sorry, this was my fault. For protocols like YModem, HW Flow
>>Control might work. I once had problems with HW flow control and
>>different protocols.
>>Nonetheless I would expect HW flow control to make things even
>>more difficult. I guess you are on a ColdFire derivate, and the
>>YModem is currently the only application really consuming
>>processor load? Then you should definitively have enough
>>processing power for a 9.6kBaud line.
>>Hm another guess: What do you do with the data received? If you
>>start storing it on a Flash Disk (or a real harddisk), things
>>might be slow there... So, whenever you perform a "write" call
>>to disk, it might wait until the data has been actually written.
>>And this might make your communication task stop for several
>>milliseconds. Hmpf. Let me look at it a bit closer. This would
>>not make your input buffer overrun. So forget this guess. Hmpf.
>>But maybe it would nevertheless make sense to try to write to
>>RAMDISK (IMFS) instead. Just to make sure.
>>Let me try another run: Maybe it you perform sort of a timed log
>>of your protocol implementation, putting additional, self-built
>>log calls to specific parts of your protocol implementation
>>("Now I am calling read, now I am back with xx bytes read").
>>Maybe you can find out, why your software seems to hang from
>>time to time.
>>I really don't think it is the termios/console mechanism which
>>generates your headache...
>>wkr,
>>Thomas.
>>>Etienne
>>>Envoyé : 5 novembre, 2004 12:19
>>>À : Etienne Fortin
>>>Objet : RE : RE : RE : RE : RE : Console problem update
>>>Etienne,
>>>>In what situation does the rawInDropped value can increase? I only
>>>>see
>>>>buffer overrun, but I really don'T have that much experience with
>>>>the
>>>>console especially on RTEMS. So, do you think that putting
> hardware
>>>>flow control to work on my faulty board would fix the problem?
>>>rawInDropped will be increased whenever a character has been
>>>received but there is no more position available in the rawInBuffer.
>>>I don't think that any kind of flow control (XON/XOFF, hardware
>>>etc) would help you, because in general the protocol itself
>>>should have some kind of flow control.
>>>When your input buffer has an overflow, obviously you get too much
>>>data.
>>>filling 1K of input buffer takes about 1 second, so I would think
>>>you look too seldomly, whether input data is available...
>>>What do you test currently? file stransfers from RTEMS to host or
>>>from host to RTEMS?
>>>Do you send big chunks of data (let's say a 1K Buffer) in situations
>>>when the output buffer is already filled? Then your "write" call
>>>will block until the whole new data block can be moved into the
>>>rawOutBuffer, and this may take too much time for your input
>>>processing...
>>>wkr,
>>>Thomas.
>>>>Etienne
>>>>Envoyé : 5 novembre, 2004 11:24
>>>>À : Etienne Fortin
>>>>Objet : RE : RE : RE : RE : Console problem update
>>>>Etienne,
>>>>head is always "ahead" of tail in the ring buffer, so when
>>>>head==tail+1, there is exactly one char in the buffer. This is ok,
> I
>>>>would say.
>>>>In the last snapshot, you have a bunch of Debug info in the output
>>>>buffer, (like "C3D 1.0.0 File Tranfer Test\r\nNeed a valid FAT12
>>>>file system on /dev/nvram0 ") I hope this does not happen during
>>>>YMOdem transfer?
>>>>Sorry for asking, but do you possibly have a flaw in your protocol
>>>>engine design? When there are more characters in the input than
>>>>expected, do you consume them properly?
>>>>Seems to get a weekend with headaches for you ?
>>>>wkr,
>>>>Thomas.
>>>>>Some more info.
>>>>>My rawInBuf is now 1024 bytes. And it gives me the same problem:
>>>>>Head go beyond Tail in rawInBuf and rawInBufDropped starts to go
>>>>>up.
>>>>>0, isem
>>>>>= 436273159, osem = 436273160, cbuf = 0x80d53be4 "ò", ccount =
>>>>>1,
> {c_iflag
>>>>>= 8450, c_oflag = 4294967230, c_cflag = 2237, c_lflag = 32768,
>>>>>c_line
>>>>>0 '\0', c_cc =
>>>>0\
>>>>00
>>>>0"
>>>>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d5407c "", Head =
>>>>>197,
>>>>>Tail = 196, Size = 1024, Semaphore = 436273162},
>>>>>rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 3,
>>>>>rawOutBuf
>>>>>{theBuf = 0x80d53c70 "\r\n\r\nC3D 1.0.0 File Tranfer
>>>>>Test\r\nNeed
>>a
>>fs_create).\r\n\r\nMount
>>>>>before)\r\nfsmount:
>>>>>mounting of \"/dev/nvram0\" to "..., Head = 413, Tail = 413,
> Size
>>>>>1024, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
>>>>>rob_idle, device = {firstOpen = 0x17a8 <console_first_open>,
>>>>>lastClose = 0x1804 <console_last_close>, pollRead = 0, write =
>>>>>0x16de <console_interrupt_write>, setAttributes = 0x172e
>>>>><console_set_attributes>, stopRemoteTx = 0x1750
>>>>><console_stop_remote_tx>, startRemoteTx = 0x177c
>>1,
>>>>>lowwater = 512, highwater = 768, rxTaskId = 0, txTaskId = 0,
>>>>>t_line
>>>>0,
>>>>>{sw_pfn
>>>>0,
>>>>>Something to do with the absence of hardware flow control?
>>>>>And now no matter what file I send, the problem appears at 12k
>>>>>for
>>>>>a 1024 buffers (sooner for a 128 bytes buffer).
>>>>>Etienne
>>>>>Envoyé : 5 novembre, 2004 09:56
>>>>>Objet : RE : RE : RE : Console problem update
>>>>>Etienne,
>>>>>a baud rate difference of 2% is still tolerable, as
>>>>>fas as I know. And you would be well below.
>>>>>I just had another look into the data structure snapshot you
>>>>>sent this morning (last night...). To my suprise, the
>>>>>"flow_ctrl" fiels is non-zero. The value 512 means, that the
>>>>>"input is controlled with XON/XOFF protocol". Maybe you should
>>>>>try to clear the "IXON" and "IXOFF" flags in the c_iflag field
>>>>>of termios settings?
>>>>>wkr,
>>>>>Thomas.
>>>>>>Hi Thomas,
>>>>>>Yes, the buffer is empty. But, it shows that at least 1161
>>>>>>characters were received. After that, termios thinks there's
> no
>>>>>>more data received or it lost sync or something else.
>>>>>>I said before that my baudrate is really 9630 and not 9600.
>>>>>>The computer is 9600. Do you think that can be the problem?
>>>>>>Etienne
>>>>>>Envoyé : 5 novembre, 2004 02:23
>>>>>>À : Etienne Fortin
>>>>>>Objet : RE : RE : Console problem update
>>>>>>Etienne,
>>>>>>from the data you sent, the input and output buffer really is
>>>>>>"empty", (for rawInBuf and rawOutBuf, "Head" and "Tail" have
> the
>>>>>>same values) but I guess you already saw this.
>>>>>>Which BSP are you using? Is it possible your console driver
>>>>>>interrupt gets stuck, when there is a receive and transmit
>>>interrupt
>>>>>>pending at the same time?
>>>>>>wkr,
>>>>>>Thomas.
>>>>>>>Hi Thomas,
>>>>>>>Yes a VERY nasty problem... It must have something to do
>>>>>>>with
>>>>>>>my comprehension and the way I implemented the console
>>>>>>>driver...
>>>But,
>>>>>>>I
>>>>>>>was able to make a lot of other things work before (I mean,
>>>>>>>the
>>>>>>>balance of
>>>>>>>RTEMS) and I got nasty problem with RTEMS before. But that
> one
>>>>>>>is special. Its so stupid! And I hate to work with transfer
>>>>>>>protocol.
>>>>>You
>>>>>>>know you'll be able to make it work, you just don't know
>>>>>>>when...
>>>>>>>Anyway, here's the snapshot of the rtems_termios_tty
>>>>>>>structure
>>>>>>>when the semaphore get stuck.
>>>>>>>= 0, isem
>>>>>>>= 436273159, osem = 436273160, cbuf = 0x80d542a4 "}", ccount
>>>>>>>= 0, cindex = 0, column = 0, read_start_column = 0, termios
>>>{c_iflag
>>>>>>>= 9474, c_oflag = 4294967230, c_cflag = 2237, c_lflag =
>>>>>>>32768, c_line
>>>>>>>0 '\0', c_cc =
>>>>>>6\
>>>>>>00
>>>>>>0\
>>>>>>00
>>>>>>0"
>>>>>>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53a98 "",
>>>>>>>Head
>>>>>>>1161, Tail = 1161, Size = 2048, Semaphore = 436273162},
> 100,
>>>>>>>rawOutBuf
>>>>>>>{theBuf = 0x80d543b0
>>>>>>>"ransfer...\r\n\r\nC\006C.\r\nrawInBuf.Size
>>>>>>>2048\r\nPress a key to begin t", Head = 17, Tail = 17, Size
>>>>>>>= 64, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
>>rob_idle,
>>>>>>>device
>>>>>>>{firstOpen = 0x17a2 <console_first_open>, lastClose = 0x17ea
>>>>>>><console_last_close>, pollRead = 0, write = 0x16dc
>>>>>>><console_interrupt_write>, setAttributes = 0x172c
>>>>>>><console_set_attributes>, stopRemoteTx = 0x174e
>>>>>>><console_stop_remote_tx>, startRemoteTx = 0x1778
>>flow_ctrl
>>>>>>>= 512, lowwater = 64, highwater = 96, rxTaskId = 0, txTaskId
>>>>>>>0, t_line = 0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg =
>>0x0},
>>>>>>>tty_rcv = {sw_pfn =
>>>>>>0,
>>>>>>>As you can see, I "hardwired" the rawInBuf to be 2048
>>>>>>>characters in size. And surprisingly enough, the Head is at
>>>>>>>offset 1161.
>>>This
>>>>>>>mean
>>>>>>>that I received the first 130 bytes packet (init packet) and
>>>>>>>some
>>>>>part
>>>>>>>of the first data packet. But for some reason, termios lost
>>>>>>>sync and lost all the next characters, stucking the
> semaphore
>>>>>>>and giving me headaches :)
>>>>>>>What do you think???
>>>>>>>And by the way, you can't imagine how glad I am to have help
>>>>>>>from all of you on RTEMS forum.
>>>>>>>Etienne Fortin
>>>>>>>Sensio
>>>>>>>Envoyé : 4 novembre, 2004 16:09
>>>>>>>Objet : RE : Console problem update
>>>>>>>Etienne,
>>>>>>>can you provide a snapshot of the termios data structures
>>>>>>>when
>>>>>>>your console input gets stuck? What values do the buffer
>>>>>>>pointers
>>>have
>>>>>>>for the raw input buffer?
>>>>>>>What baud rate are you using currently?
>>>>>>>What happens, if you write a simple application with two
>>>>>>>tasks, one sending a 1K buffer to the console, one receiving
>>>>>>>it, and
>>>putting
>>>>>>>the console into loopback mode (with a nice little wire
>>>>>>>between
>>>>pin
>>>>>>>2 and 3 of your serial connector)? Does it also hand in that
>>>>>>>case?
>>>>>>>You really seem to have a nasty problem there...
>>>>>>>I have been using termios code for machine interfaces back
>>>>>>>with
>>>>>>>RTEMS version 4.0.0, and I never had similar problems...
>>>>>>>wkr,
>>>>>>>Thomas.
>>>>>>>>I don'T know why I tought that even after releasing the
>>>>>>>>sempahore,
>>>>>>>>I was still stuck in the idle thread. To the contrary!
>>>>>>>>Forcing the
>>>>>>>>release of the semaphore make the task continue to execute
>>>>>>>>code and
>>>>>>I
>>>>>>>>eventually get out of the code with an error (that's ok
>>>>>>>>since the semaphore was forced to be released so no valid
>>>>>>>>data is there waiting)...
>>>>>>>>The question now is why the code is not notified of new
>>>>>>>>characters. Is
>>>>>>>>it possible that the termios code, being designed for
>>>>>>>>"human"
>>>>>>>>interraction (at least I presume), can't cope with
> sustained
>>>>>>>>binary data transfer and so I lost data and eventually the
>>>>>>>>semaphore is struck waiting for characters that will never
>>>>>>>>come?
>>>>>>>>Is it possible?
>>>>>>>>Etienne Fortin
>>>>>>>>Sensio
>>>>>>>>De : Joel Sherrill <joel at OARcorp.com>
>>>>>>>>[mailto:joel.sherrill at OARcorp.com]
>>>>>>>>Envoyé : 4 novembre, 2004 15:21
>>>>>>>>À : Etienne Fortin
>>>>>>>>Objet : Re: Console problem update
>>>>>>>>>Hello all, its me again, the console guy :)
>>>>>>>>>Little update for the ones that have an interest, or
>>>>>>>>>wish
>>>>>>>>>to
>>>>>>>>>help me on that matter.
>>>>>>>>Is your interrupt an RTEMS ISR or a raw one directly
>>>>>>>>connected to hardware? If you do not go through the RTEMS
>>>>>>>>ISR wrapper, you
>>>>>will
>>>>>>>>NEVER schedule out of an interrupt.
>>>>>>>>Also are you sure you are geting the serial port
>>>>>>>>interrupts?
>>>>>>>>>I tricked RTEMS to release the semaphore at each clock
>>>>>>>>>tick
>>>>>>>>>to
>>>>>>>>>make sure the semaphore was the problem. And surprise
>>>>>>>>>surprise!
>>>>>It
>>>>>>>>>still hang in the idle thread!!!!!!!!!
>>>>>>>>>Theory: My task/scheduler/... config is fu***d up.
>>>>>>>>>Anyone here thinks it can be possible? For what I know
>>>>>>>>>of the problem so far, it
>>>>>>seems
>>>>>>>>>that as soon as the idle thread is entered, no other
>>>>>>>>>thread ever
>>>>>>>gets
>>>>>>>>>executed... Really seems a config problem to me...
>>>>>>>>>Idea someone?
>>>>>>>>>Etienne Fortin
>>>>>>>>>Sensio
>>>>>>>>Joel Sherrill, Ph.D. Director of Research &
>>>>>Development
>>>>>>>>joel at OARcorp.com On-Line Applications
>>Research
>>>>>>>>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>>>>> Support Available (256) 722-9985
>>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>>Thomas Doerfler Herbststrasse 8
>>>>>>>D-82178 Puchheim Germany
>>>>>>>email: Thomas.Doerfler at imd-systems.de
>>>>>>>PGP public key available at: http://www.imd-
>>>>>>>systems.de/pgp_keys.htm
>>>PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
joel at OARcorp.com On-Line Applications Research
