Console problem update
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Fri Nov 5 20:01:55 UTC 2004
Joel,
> That sounds like you have CR/LF expansion on.  Are you sure
> you have the termios settings for NO canonical processing
> turned on?
It really sound like a conversion. But the term
"canonical" maybe is a bit general. Switching off
the termios option "I_CANON" does not automatically
disable all conversions. And I guess Etienne has
left one of them on.
> > Oh my, where would I be without open source RTEMS! :)
> It is really nice to be able to trace through every line of code
> on a piece of target hardware.
> --joel
> > Etienne
> > -----Message d'origine-----
> > De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> > Envoyé : 5 novembre, 2004 14:29
> > À : Etienne Fortin
> > Objet : RE : RE : RE : RE : RE : RE : RE : Console problem update
> > Etienne,
> > first thing first: If head is "behind" tail, if is
> > still beyond, but has reached the physical end of
> > the ring buffer and therefore started over at the
> > beginning (its a ring...).
> > Second: I suspect my code snipplet some days ago is
> > not sufficent for your port :-(((
> > Your "c_iflag" selects XON/XOFF flow control for the
> > output. I don't think this is a good idea.
> > And your c_oflag has MANY bits set, which really
> > doesn't make sense. did you miss a "&" in a
> > expression like:
> > c_oflag &= ~(OPOST|.....)
> > Look into a termios man page and clear all the
> > c_oflag options you don't need. I would even guess
> > (oh no, not again!) that c_oflag=0 would be nice for
> > you...
> > Hm, maybe this makes things a bit better...
> > wkr,
> > Thomas.,
> >>Hi Thomas,
> >>Thanks again for your help.
> >>And no, I really don't think that termios is the problem. To the
> >>contrary, it looks like a well proven design that worked for all of
> >>you.
> >>But, the problem is really nasty, like you said, and there's so much
> >>possibility regarding the cause of all this!
> >>An update:
> >>With HW flow control (driving RTS only and don't care for CTS since
> >>it's not correctly routed on the m5282lite from Axiom), I don't get
> >>any more buffer overrun. But, it continue to hang after about 12k (8k
> >>for another file, probably something else with another) with the
> >>following values in
> >>rtems_termios_tty:
> >>$2 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
> >>= 436273159, osem = 436273160, cbuf = 0x80d537e4 "", ccount = 0,
> >>cindex = 0, column = 0, read_start_column = 0, termios = {c_iflag =
> >>8450, c_oflag = 4294967230, c_cflag = 2147485885, c_lflag = 32768,
> >>c_line = 0 '\0', c_cc =
> >>"\003\034\177\025\004\n\001\000\021\023\032\000\022\017\027\026\000\00
> >>0"
> >>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c
> >>"\001\220\020\001\001\037c\002\001Ä\204", Head = 840, Tail = 1203,
> > Size
> >>= 2048, Semaphore = 436273162}, rawInBufSemaphoreOptions = 0,
> >>rawInBufSemaphoreTimeout = 100, rawInBufSemaphoreFirstTimeout = 0,
> >>rawInBufDropped = 0, rawOutBuf = {theBuf = 0x80d53870 "\n\nC3D 1.0.0
> >>File Tranfer Test\nNeed a valid FAT12 file system on /dev/nvram0 (run
> >>fs_create).\n\nMount DOSFS file system on /dev/nvram0 (run fs_create
> >>before)\nfsmount: mounting of \"/dev/nvram0\" to \"/mnt/"..., Head =
> >>395, Tail = 395, Size = 1024, Semaphore = 436273161}, t_dqlen = 0,
> >>rawOutBufState = rob_idle, device = {firstOpen = 0x17ec
> >><console_first_open>, lastClose = 0x1848 <console_last_close>,
> > pollRead
> >>= 0, write = 0x1722 <console_interrupt_write>, setAttributes = 0x1772
> >><console_set_attributes>, stopRemoteTx = 0x1794
> >><console_stop_remote_tx>, startRemoteTx = 0x17c0
> >><console_start_remote_tx>, outputUsesInterrupts = 1}, flow_ctrl = 256,
> >>lowwater = 1024, highwater = 1536, rxTaskId = 0, txTaskId = 0, t_line
> >>0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0}, tty_rcv = {sw_pfn
> >>0, sw_arg = 0x0}, tty_rcvwakeup = 0}
> >>As you can see, no data dropped at all (rawInBufDropped == 0). But,
> >>Head == 840 && Tail == 1203... What does this mean? There's 1203-840
> >>characters in the buffer? Shouldn’t be since you said that Tail < Head
> >>means characters in the buffer. So it means there's 1203-840 places
> >>available in the buffer?
> >>And for a file it hang in the semaphore, for anothers it bump out of
> >>my Ymodem code with an error... If you want (I would appreciate but
> >>you already put time into this), could you look at the configuration
> >>of the termios structure. I suspect something about characters being
> >>wrongly interpreted somewhere in the flow of data.
> >>Etienne
> >>P.S.
> >>Another file, same behavior:
> >>$3 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
> >>= 436273159, osem = 436273160, cbuf = 0x80d537e4 "ò", ccount = 1,
> >>cindex = 1, column = 0, read_start_column = 0, termios = {c_iflag =
> >>0"
> >>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c "", Head = 197,
> >>Tail = 1223, Size = 2048, Semaphore = 436273162},
> >>rawInBufSemaphoreOptions = 0, rawInBufSemaphoreTimeout = 100,
> >>rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 0, rawOutBuf =
> >>{theBuf = 0x80d53870 "\n\nC3D 1.0.0 File Tranfer Test\nNeed a valid
> >>FAT12 file system on /dev/nvram0 (run fs_create).\n\nMount DOSFS file
> >>system on /dev/nvram0 (run fs_create before)\nfsmount: mounting of
> >>\"/dev/nvram0\" to \"/mnt/"..., Head = 399, Tail = 399, Size = 1024,
> >>Semaphore = 436273161}, t_dqlen = 0, rawOutBufState = rob_idle, device
> >>{firstOpen = 0x17ec <console_first_open>, lastClose = 0x1848
> >><console_last_close>, pollRead = 0, write = 0x1722
> >>Envoyé : 5 novembre, 2004 13:41
> >>À : Etienne Fortin; rtems-users at rtems.com
> >>Cc : rtems-users at rtems.com
> >>Objet : RE : RE : RE : RE : RE : RE : Console problem update
> >>Etienne,
> >>>The sender of a file in YMODEM waits for an ACK to be received
> >>>before
> >>>sending the next packet. So, I can wait forever (at least a little
> >>>less than the timeout value of YMODEM which is, if I'm not mystaken,
> >>>about 30
> >>>seconds) between each packet.
> >>>And I don't understand why you say hardware flow control would not
> >>>help. If RTS is negated during transfer because the buffer is about
> > to
> >>>get filled completely, then the transmitter (sender) will stop and
> >>>wait for RTS (its CTS) to get asserted again before continuing. This
> >>>would ensure that the input buffer never overflow. Am I
> > understanding
> >>>correctly or is there something I miss in my comprehension?
> >>Sorry, this was my fault. For protocols like YModem, HW Flow
> >>Control might work. I once had problems with HW flow control and
> >>different protocols.
> >>Nonetheless I would expect HW flow control to make things even
> >>more difficult. I guess you are on a ColdFire derivate, and the
> >>YModem is currently the only application really consuming
> >>processor load? Then you should definitively have enough
> >>processing power for a 9.6kBaud line.
> >>Hm another guess: What do you do with the data received? If you
> >>start storing it on a Flash Disk (or a real harddisk), things
> >>might be slow there... So, whenever you perform a "write" call
> >>to disk, it might wait until the data has been actually written.
> >>And this might make your communication task stop for several
> >>milliseconds.  Hmpf. Let me look at it a bit closer. This would
> >>not make your input buffer overrun. So forget this guess. Hmpf.
> >>But maybe it would nevertheless make sense to try to write to
> >>RAMDISK (IMFS) instead. Just to make sure.
> >>Let me try another run: Maybe it you perform sort of a timed log
> >>of your protocol implementation, putting additional, self-built
> >>log calls to specific parts of your protocol implementation
> >>("Now I am calling read, now I am back with xx bytes read").
> >>Maybe you can find out, why your software seems to hang from
> >>time to time.
> >>I really don't think it is the termios/console mechanism which
> >>generates your headache...
> >>wkr,
> >>Thomas.
> >>>Etienne
> >>>Envoyé : 5 novembre, 2004 12:19
> >>>À : Etienne Fortin
> >>>Objet : RE : RE : RE : RE : RE : Console problem update
> >>>Etienne,
> >>>>In what situation does the rawInDropped value can increase? I only
> >>>>see
> >>>>buffer overrun, but I really don'T have that much experience with
> >>>>the
> >>>>console especially on RTEMS. So, do you think that putting
> > hardware
> >>>>flow control to work on my faulty board would fix the problem?
> >>>rawInDropped will be increased whenever a character has been
> >>>received but there is no more position available in the rawInBuffer.
> >>>I don't think that any kind of flow control (XON/XOFF, hardware
> >>>etc) would help you, because in general the protocol itself
> >>>should have some kind of flow control.
> >>>When your input buffer has an overflow, obviously you get too much
> >>>data.
> >>>filling 1K of input buffer takes about 1 second, so I would think
> >>>you look too seldomly, whether input data is available...
> >>>What do you test currently? file stransfers from RTEMS to host or
> >>>from host to RTEMS?
> >>>Do you send big chunks of data (let's say a 1K Buffer) in situations
> >>>when the output buffer is already filled? Then your "write" call
> >>>will block until the whole new data block can be moved into the
> >>>rawOutBuffer, and this may take too much time for your input
> >>>processing...
> >>>wkr,
> >>>Thomas.
> >>>>Etienne
> >>>>Envoyé : 5 novembre, 2004 11:24
> >>>>À : Etienne Fortin
> >>>>Objet : RE : RE : RE : RE : Console problem update
> >>>>Etienne,
> >>>>head is always "ahead" of tail in the ring buffer, so when
> >>>>head==tail+1, there is exactly one char in the buffer. This is ok,
> > I
> >>>>would say.
> >>>>In the last snapshot, you have a bunch of Debug info in the output
> >>>>buffer, (like "C3D 1.0.0 File Tranfer Test\r\nNeed a valid FAT12
> >>>>file system on /dev/nvram0 ") I hope this does not happen during
> >>>>YMOdem transfer?
> >>>>Sorry for asking, but do you possibly have a flaw in your protocol
> >>>>engine design? When there are more characters in the input than
> >>>>expected, do you consume them properly?
> >>>>Seems to get a weekend with headaches for you ?
> >>>>wkr,
> >>>>Thomas.
> >>>>>Some more info.
> >>>>>My rawInBuf is now 1024 bytes. And it gives me the same problem:
> >>>>>Head go beyond Tail in rawInBuf and rawInBufDropped starts to go
> >>>>>up.
> >>>>>0, isem
> >>>>>= 436273159, osem = 436273160, cbuf = 0x80d53be4 "ò", ccount =
> >>>>>1,
> > {c_iflag
> >>>>>= 8450, c_oflag = 4294967230, c_cflag = 2237, c_lflag = 32768,
> >>>>>c_line
> >>>>>0 '\0', c_cc =
> >>>>0\
> >>>>00
> >>>>0"
> >>>>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d5407c "", Head =
> >>>>>197,
> >>>>>Tail = 196, Size = 1024, Semaphore = 436273162},
> >>>>>rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 3,
> >>>>>rawOutBuf
> >>>>>{theBuf = 0x80d53c70 "\r\n\r\nC3D 1.0.0 File Tranfer
> >>>>>Test\r\nNeed
> >>a
> >>fs_create).\r\n\r\nMount
> >>>>>before)\r\nfsmount:
> >>>>>mounting of \"/dev/nvram0\" to "..., Head = 413, Tail = 413,
> > Size
> >>>>>1024, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
> >>>>>rob_idle, device = {firstOpen = 0x17a8 <console_first_open>,
> >>>>>lastClose = 0x1804 <console_last_close>, pollRead = 0, write =
> >>>>>0x16de <console_interrupt_write>, setAttributes = 0x172e
> >>>>><console_set_attributes>, stopRemoteTx = 0x1750
> >>>>><console_stop_remote_tx>, startRemoteTx = 0x177c
> >>1,
> >>>>>lowwater = 512, highwater = 768, rxTaskId = 0, txTaskId = 0,
> >>>>>t_line
> >>>>0,
> >>>>>{sw_pfn
> >>>>0,
> >>>>>Something to do with the absence of hardware flow control?
> >>>>>And now no matter what file I send, the problem appears at 12k
> >>>>>for
> >>>>>a 1024 buffers (sooner for a 128 bytes buffer).
> >>>>>Etienne
> >>>>>Envoyé : 5 novembre, 2004 09:56
> >>>>>Objet : RE : RE : RE : Console problem update
> >>>>>Etienne,
> >>>>>a baud rate difference of 2% is still tolerable, as
> >>>>>fas as I know. And you would be well below.
> >>>>>I just had another look into the data structure snapshot you
> >>>>>sent this morning (last night...). To my suprise, the
> >>>>>"flow_ctrl" fiels is non-zero. The value 512 means, that the
> >>>>>"input is controlled with XON/XOFF protocol". Maybe you should
> >>>>>try to clear the "IXON" and "IXOFF" flags in the c_iflag field
> >>>>>of termios settings?
> >>>>>wkr,
> >>>>>Thomas.
> >>>>>>Hi Thomas,
> >>>>>>Yes, the buffer is empty. But, it shows that at least 1161
> >>>>>>characters were received. After that, termios thinks there's
> > no
> >>>>>>more data received or it lost sync or something else.
> >>>>>>I said before that my baudrate is really 9630 and not 9600.
> >>>>>>The computer is 9600. Do you think that can be the problem?
> >>>>>>Etienne
> >>>>>>Envoyé : 5 novembre, 2004 02:23
> >>>>>>À : Etienne Fortin
> >>>>>>Objet : RE : RE : Console problem update
> >>>>>>Etienne,
> >>>>>>from the data you sent, the input and output buffer really is
> >>>>>>"empty", (for rawInBuf and rawOutBuf, "Head" and "Tail" have
> > the
> >>>>>>same values) but I guess you already saw this.
> >>>>>>Which BSP are you using? Is it possible your console driver
> >>>>>>interrupt gets stuck, when there is a receive and transmit
> >>>interrupt
> >>>>>>pending at the same time?
> >>>>>>wkr,
> >>>>>>Thomas.
> >>>>>>>Hi Thomas,
> >>>>>>>Yes a VERY nasty problem... It must have something to do
> >>>>>>>with
> >>>>>>>my comprehension and the way I implemented the console
> >>>>>>>driver...
> >>>But,
> >>>>>>>I
> >>>>>>>was able to make a lot of other things work before (I mean,
> >>>>>>>the
> >>>>>>>balance of
> >>>>>>>RTEMS) and I got nasty problem with RTEMS before. But that
> > one
> >>>>>>>is special. Its so stupid! And I hate to work with transfer
> >>>>>>>protocol.
> >>>>>You
> >>>>>>>know you'll be able to make it work, you just don't know
> >>>>>>>when...
> >>>>>>>Anyway, here's the snapshot of the rtems_termios_tty
> >>>>>>>structure
> >>>>>>>when the semaphore get stuck.
> >>>>>>>= 0, isem
> >>>>>>>= 436273159, osem = 436273160, cbuf = 0x80d542a4 "}", ccount
> >>>>>>>= 0, cindex = 0, column = 0, read_start_column = 0, termios
> >>>{c_iflag
> >>>>>>>= 9474, c_oflag = 4294967230, c_cflag = 2237, c_lflag =
> >>>>>>>32768, c_line
> >>>>>>>0 '\0', c_cc =
> >>>>>>6\
> >>>>>>00
> >>>>>>0\
> >>>>>>00
> >>>>>>0"
> >>>>>>>}, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53a98 "",
> >>>>>>>Head
> >>>>>>>1161, Tail = 1161, Size = 2048, Semaphore = 436273162},
> > 100,
> >>>>>>>rawOutBuf
> >>>>>>>{theBuf = 0x80d543b0
> >>>>>>>"ransfer...\r\n\r\nC\006C.\r\nrawInBuf.Size
> >>>>>>>2048\r\nPress a key to begin t", Head = 17, Tail = 17, Size
> >>>>>>>= 64, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
> >>rob_idle,
> >>>>>>>device
> >>>>>>>{firstOpen = 0x17a2 <console_first_open>, lastClose = 0x17ea
> >>>>>>><console_last_close>, pollRead = 0, write = 0x16dc
> >>>>>>><console_interrupt_write>, setAttributes = 0x172c
> >>>>>>><console_set_attributes>, stopRemoteTx = 0x174e
> >>>>>>><console_stop_remote_tx>, startRemoteTx = 0x1778
> >>flow_ctrl
> >>>>>>>= 512, lowwater = 64, highwater = 96, rxTaskId = 0, txTaskId
> >>>>>>>0, t_line = 0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg =
> >>0x0},
> >>>>>>>tty_rcv = {sw_pfn =
> >>>>>>0,
> >>>>>>>As you can see, I "hardwired" the rawInBuf to be 2048
> >>>>>>>characters in size. And surprisingly enough, the Head is at
> >>>>>>>offset 1161.
> >>>This
> >>>>>>>mean
> >>>>>>>that I received the first 130 bytes packet (init packet) and
> >>>>>>>some
> >>>>>part
> >>>>>>>of the first data packet. But for some reason, termios lost
> >>>>>>>sync and lost all the next characters, stucking the
> > semaphore
> >>>>>>>and giving me headaches :)
> >>>>>>>What do you think???
> >>>>>>>And by the way, you can't imagine how glad I am to have help
> >>>>>>>from all of you on RTEMS forum.
> >>>>>>>Etienne Fortin
> >>>>>>>Sensio
> >>>>>>>Envoyé : 4 novembre, 2004 16:09
> >>>>>>>Objet : RE : Console problem update
> >>>>>>>Etienne,
> >>>>>>>can you provide a snapshot of the termios data structures
> >>>>>>>when
> >>>>>>>your console input gets stuck? What values do the buffer
> >>>>>>>pointers
> >>>have
> >>>>>>>for the raw input buffer?
> >>>>>>>What baud rate are you using currently?
> >>>>>>>What happens, if you write a simple application with two
> >>>>>>>tasks, one sending a 1K buffer to the console, one receiving
> >>>>>>>it, and
> >>>putting
> >>>>>>>the console into loopback mode (with a nice little wire
> >>>>>>>between
> >>>>pin
> >>>>>>>2 and 3 of your serial connector)? Does it also hand in that
> >>>>>>>case?
> >>>>>>>You really seem to have a nasty problem there...
> >>>>>>>I have been using termios code for machine interfaces back
> >>>>>>>with
> >>>>>>>RTEMS version 4.0.0, and I never had similar problems...
> >>>>>>>wkr,
> >>>>>>>Thomas.
> >>>>>>>>I don'T know why I tought that even after releasing the
> >>>>>>>>sempahore,
> >>>>>>>>I was still stuck in the idle thread. To the contrary!
> >>>>>>>>Forcing the
> >>>>>>>>release of the semaphore make the task continue to execute
> >>>>>>>>code and
> >>>>>>I
> >>>>>>>>eventually get out of the code with an error (that's ok
> >>>>>>>>since the semaphore was forced to be released so no valid
> >>>>>>>>data is there waiting)...
> >>>>>>>>The question now is why the code is not notified of new
> >>>>>>>>characters. Is
> >>>>>>>>it possible that the termios code, being designed for
> >>>>>>>>"human"
> >>>>>>>>interraction (at least I presume), can't cope with
> > sustained
> >>>>>>>>binary data transfer and so I lost data and eventually the
> >>>>>>>>semaphore is struck waiting for characters that will never
> >>>>>>>>come?
> >>>>>>>>Is it possible?
> >>>>>>>>Etienne Fortin
> >>>>>>>>Sensio
> >>>>>>>>De : Joel Sherrill <joel at OARcorp.com>
> >>>>>>>>[mailto:joel.sherrill at OARcorp.com]
> >>>>>>>>Envoyé : 4 novembre, 2004 15:21
> >>>>>>>>À : Etienne Fortin
> >>>>>>>>Objet : Re: Console problem update
> >>>>>>>>Etienne Fortin wrote:
> >>>>>>>>>Hello all, its me again, the console guy :)
> >>>>>>>>>Little update for the ones that have an interest, or
> >>>>>>>>>wish
> >>>>>>>>>to
> >>>>>>>>>help me on that matter.
> >>>>>>>>Is your interrupt an RTEMS ISR or a raw one directly
> >>>>>>>>connected to hardware?  If you do not go through the RTEMS
> >>>>>>>>ISR wrapper, you
> >>>>>will
> >>>>>>>>NEVER schedule out of an interrupt.
> >>>>>>>>Also are you sure you are geting the serial port
> >>>>>>>>interrupts?
> >>>>>>>>>I tricked RTEMS to release the semaphore at each clock
> >>>>>>>>>tick
> >>>>>>>>>to
> >>>>>>>>>make sure the semaphore was the problem. And surprise
> >>>>>>>>>surprise!
> >>>>>It
> >>>>>>>>>still hang in the idle thread!!!!!!!!!
> >>>>>>>>>Theory: My task/scheduler/... config is fu***d up.
> >>>>>>>>>Anyone here thinks it can be possible? For what I know
> >>>>>>>>>of the problem so far, it
> >>>>>>seems
> >>>>>>>>>that as soon as the idle thread is entered, no other
> >>>>>>>>>thread ever
> >>>>>>>gets
> >>>>>>>>>executed... Really seems a config problem to me...
> >>>>>>>>>Idea someone?
> >>>>>>>>>Etienne Fortin
> >>>>>>>>>Sensio
> >>>>>>>>Joel Sherrill, Ph.D.             Director of Research &
> >>>>>Development
> >>>>>>>>joel at OARcorp.com                 On-Line Applications
> >>Research
> >>>>>>>>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>>>>>>>    Support Available             (256) 722-9985
> >>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
> >>>>>>>Thomas Doerfler           Herbststrasse 8
> >>>>>>>D-82178 Puchheim          Germany
> >>>>>>>email:    Thomas.Doerfler at imd-systems.de
> >>>>>>>PGP public key available at: http://www.imd-
> >>>>>>>systems.de/pgp_keys.htm
> >>>PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
