Setting up ramdisk with dosfs
Eugeny S. Mints emints at ru.mvista.com
Tue Nov 9 16:49:56 UTC 2004
Joel Sherrill  wrote:
> Eugeny S. Mints wrote:
>> Greetings,
>> Thomas Doerfler wrote:
>>> Hi,
>>> AFAIK the ramdisk would work fine with the MSDOS filesystem, but it
>>> is not formatted :-(
>> Exactly. Ramdisk works fine with DOSFS since I used ramdisk during
>> DOSFS development:) And again - exactly - a ramdisk needs to be
>> formatted by any means out of RTEMS since Thomas msdos_format for
>> RTEMS is the work in progress (yet:).
>>> I am currently developing a msdos_format function which should solve
>>> this problem.
>>>> Hi.
>>>> I want to use the ramdisk with dosfs but has some problems.
>>>> I am running on a sun solaris with target ERC32. Using TSIM as
>>>> simulator.
>>>> Want to modify the fileio sample to use ramdisk instead of ata.
>>>> My questions are:
>>>> What should I initialize? (I added RAMDISK_TABLE_ENTRY to the Device
>>>> table
>>>> and this seems to work fine.)
>> In addition to the RAMDISK_TABLE_ENTRY you need to define at least one
>> ramdisk itself - rtems_ramdisk_configuration[] array of type
>> rtems_ramdisk_config (please, see
>> cpukit/libblock/include/rtems/ramdisk.h - there are good comments
>> there). The rtems_ramdisk_configuration[] array is expected to be
>> exported by a bsp.
>> It seems one time (about june of 2002) I sent Angelo Fraietta
>> <angelo_f at bigpond dot com> the ramdisk application example.
>> 2Angelo: If it possible, please re-post the example on the list.
> Is the attached program something like it?
Yes, thanks Joel. (I've searched mail archive for 10 minutes but failed
to find)
>> Regards,
>>         Eugeny
>>>> I am trying to run rtems_ide_part_table_initialize(dev) but it
>>>> returns '25'
>>>> and 'not a char device' (the ramdisk is accessed). Must I use ide_part?
>>>> I really could use a step by step instruction how to init and mount a
>>>> ramdisk and use msdos with it.
>>>> Any information would be greatly appreciated.
>>>> Regards
>>>> Daniel Gustavsson
>>> IMD Ingenieurbuero fuer Microcomputertechnik
>>> Thomas Doerfler           Herbststrasse 8
>>> D-82178 Puchheim          Germany
>>> email:    Thomas.Doerfler at imd-systems.de
>>> PGP public key available at: http://www.imd-
>>> systems.de/pgp_keys.htm
