Setting up ramdisk with dosfs
Daniel Gustafsson
daniel.gustafsson at space.se
Wed Nov 10 08:00:58 UTC 2004
>Joel Sherrill wrote:
>> Eugeny S. Mints wrote:
>>> Greetings,
>>> Thomas Doerfler wrote:
>>>> Hi,
>>>> AFAIK the ramdisk would work fine with the MSDOS
>filesystem, but it
>>>> is not formatted :-(
How soon can the format function be released, at least as an alpha or a beta
version?
>>> Exactly. Ramdisk works fine with DOSFS since I used ramdisk during
>>> DOSFS development:) And again - exactly - a ramdisk needs to be
>>> formatted by any means out of RTEMS since Thomas msdos_format for
>>> RTEMS is the work in progress (yet:).
How can I format the ramdisk out of Rtems without the format function?
>>>> I am currently developing a msdos_format function which
>should solve
>>>> this problem.
>>>>> Hi.
>>>>> I want to use the ramdisk with dosfs but has some problems.
>>>>> I am running on a sun solaris with target ERC32. Using TSIM as
>>>>> simulator.
>>>>> Want to modify the fileio sample to use ramdisk instead of ata.
>>>>> My questions are:
>>>>> What should I initialize? (I added RAMDISK_TABLE_ENTRY to
>the Device
>>>>> table
>>>>> and this seems to work fine.)
>>> In addition to the RAMDISK_TABLE_ENTRY you need to define
>at least one
>>> ramdisk itself - rtems_ramdisk_configuration[] array of type
>>> rtems_ramdisk_config (please, see
>>> cpukit/libblock/include/rtems/ramdisk.h - there are good comments
>>> there). The rtems_ramdisk_configuration[] array is expected to be
>>> exported by a bsp.
This works fine...
>>> It seems one time (about june of 2002) I sent Angelo Fraietta
>>> <angelo_f at bigpond dot com> the ramdisk application example.
>>> 2Angelo: If it possible, please re-post the example on the list.
>> Is the attached program something like it?
>Yes, thanks Joel. (I've searched mail archive for 10 minutes
>but failed
>to find)
The program works fine in TSIM, thanks.
>>> Regards,
>>> Eugeny
>>>>> I am trying to run rtems_ide_part_table_initialize(dev) but it
>>>>> returns '25'
>>>>> and 'not a char device' (the ramdisk is accessed). Must I
>use ide_part?
>>>>> I really could use a step by step instruction how to init
>and mount a
>>>>> ramdisk and use msdos with it.
>>>>> Any information would be greatly appreciated.
>>>>> Regards
>>>>> Daniel Gustavsson
>>>> IMD Ingenieurbuero fuer Microcomputertechnik
>>>> Thomas Doerfler Herbststrasse 8
>>>> D-82178 Puchheim Germany
>>>> email: Thomas.Doerfler at imd-systems.de
>>>> PGP public key available at: http://www.imd-
>>>> systems.de/pgp_keys.htm
