error 105
Steve Holle sholle at link-comm.com
Fri Oct 1 14:11:16 UTC 2004
I increased the value in my linkcmds file as follows :
/* running out of heap, doubling from 0x80000 to 0x100000 */
_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x100000;
Is that the correct way to do it?
At 05:03 AM 10/1/2004, Joel Sherrill <joel at OARcorp.com> wrote:
>I recall that much of that memory comes from the C Program Heap
>so make sure that you have plenty of memory assigned to it.
>It's early and I am still packing so I hope I got that right. :)
>--joel
>Steve Holle wrote:
>>I increased mbuf capacity and cluster to the values show below and the
>>same problem occured.
>>         struct rtems_bsdnet_config rtems_bsdnet_config =
>>                 &netdriver_config,
>>                 #if (defined (RTEMS_USE_BOOTP))
>>                         rtems_bsdnet_do_bootp,
>>                         75,
>>                         265*1024, // Expanded mbuf capacity.
>>                         512*1024, // Expanded mbuf cluster capacity.
>>                 #else
>>                         NULL,
>>                         75,
>>                         0, // Default mbuf capacity.
>>                         0, // Default mbuf cluster capacity.
>>                 #endif
>>                 // See below for real example
>>           NULL,
>>// Host name.
>>           NULL,
>>// Domain name.
>>           NULL,
>>// Gateway.
>>           NULL,
>>// Log host.
>>           {NULL},
>>// Name server(s).
>>     {NULL}
>>// NTP server(s)
>>At 03:49 PM 9/30/2004, Chris Johns wrote:
>>>Steve Holle wrote:
>>>>I'm trying to get BOOTP running, and when I enable it I get the following :
>>>>RTEMS: BOOTP call failed -- error 105
>>>>Where would I find out what error 105 is?
>>>To find I do:
>>>  $ cd rtems/cpukit
>>>  $ grep -r "BOOTP call failed" *
>>>  libnetworking/nfs/bootp_subr.c: panic("BOOTP call failed -- error %d",
>>> error);
>>>>Any idea what's causing it?
>>>Then looking at the code I see it is an error code from the function
>>>'bootpc_call'. Another grep shows this function is in the same file, and
>>>looks like it is the result of calls to socket type functions.
>>>A look in errno.h gives:
>>>  #define ENOBUFS 105     /* No buffer space available */
>>>I see 'bootp_call' returns this value if no mbufs are available.
>>>It your networking code ok ?
>>>  Chris Johns
>>Steve Holle
>>Link Communications, Inc.
>>1035 Cerise Rd.
>>Billings, MT  59101
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel at OARcorp.com                 On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>    Support Available             (256) 722-9985
Steve Holle
1035 Cerise Rd.
Billings, MT  59101
