Putting debug info in rtems files
Kamen Penev kamen at penev.net
Sat Oct 9 00:47:40 UTC 2004
My intuition is this is a linker problem. Check your linker script and
the invocation of the linker. Make sure you are not throwing away the
stabs sections.
Kamen
Smith, Gene wrote:
> I want debug info in my rtems files. When I configure with
> --enable-rtems-debug all the gcc calls during make have the flags "-g
> -g" (-g twice!). And there is still no debug info in the final result
> according to objdump -g. This applies also to the hello world example
> app as well as the kernel files. The final result is not being
> stripped and I can see c source lines in the test.exe file with
> objdump -Sx. Possibly gcc needs the flag -gstabs for useful debug info
> to appear in the final object?
> The gdb manual talks about having source file paths in your executable
> as part of the debug info. How is this accomplished in the the rtems
> build?
> -gene
