Catching Interrupts
Mark VanderVoord
markvandervoord at yahoo.com
Tue Oct 12 12:15:45 UTC 2004
I am attempting to write a response to an interrupt
under RTEMS for the MIPS AU1100. I must be missing
something, though, as the handler is never called. I
register the handler as follows:
rtems_isr_entry old_entry;
rtems_status_code status;
status =
rtems_interrupt_catch(spi_isr,4,&old_entry); //4 is
the SSI0 vector on the AU1100
if (status != RTEMS_SUCCESSFUL) {
//handle error
*(unsigned int*)(0xB16000008) = 0x00000002;
//enable the done interrupt
This routine returns an RTEMS_SUCCESSFUL. The
function is as below:
rtems_isr spi_isr(rtems_vector_number vector) {
puts("spi_isr");
*(unsigned int*)(0xB16000004) = 0x0000000E; //clear
interrupts
This function is never called, even though polling the
interrupt register shows that it should be. Any
ideas?
Thanks!
Mark
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
