Catching Interrupts
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Tue Oct 12 12:41:51 UTC 2004
Hello Mark,
I don't know about the MIPS architecture, but I am
quite sure you should NEVER call I/O functions from
within an ISR.
wkr,
Thomas.
> I am attempting to write a response to an interrupt
> under RTEMS for the MIPS AU1100.  I must be missing
> something, though, as the handler is never called.  I
> register the handler as follows:
>    rtems_isr_entry old_entry;
>    rtems_status_code status;
>    status =
> rtems_interrupt_catch(spi_isr,4,&old_entry); //4 is
> the SSI0 vector on the AU1100
>    if (status != RTEMS_SUCCESSFUL) {
>       //handle error
>    *(unsigned int*)(0xB16000008) = 0x00000002;
> //enable the “done” interrupt
> This routine returns an RTEMS_SUCCESSFUL.  The
> function is as below:
> rtems_isr spi_isr(rtems_vector_number vector) {
>    puts("spi_isr");
>    *(unsigned int*)(0xB16000004) = 0x0000000E; //clear
> interrupts
> This function is never called, even though polling the
> interrupt register shows that it should be.  Any
> ideas?
> Thanks!
> Mark
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
