Catching Interrupts
Jay Monkman jtm-list-rtems at smoothsmoothie.com
Tue Oct 12 19:38:57 UTC 2004
Are you using my code? I vaguely remember fixing a problem with the
interrupt numbering on the au1x000. If it is based on mine, is it the
latest (http://www.lopingdog.com/rtems)?
> This function is never called, even though polling the
> interrupt register shows that it should be.  Any
> ideas?
So, ic_req0int or ic_req1int has bit 4 set? Does ic_maskrd also have
bit 4 set?
