Ticker problem on ppc405
Gene Smith gds at chartertn.net
Mon Oct 18 03:46:02 UTC 2004
I have tried to run the ticker example with no changes. I can see that
it installs a interrupt handler for a Programmable Interval Timer (PIT)
called from the typical location 0x1000 (with EVPR set to 0). However,
when it actually runs I rarely see a vector to 0x1000. The first
interrupt that occurs is usually to location 0x200 which is a machine
check (bus error). When the machine check tries to branch to its actual
handler (in _ISR_Handler) it looks like it sees a zero pointer which in
turn causes a "Program" interrupt at location 0x700, which in turn
causes a branch to zero and another Program interrupt, ad infinitum.
I only see explicit handlers being installed for the UART (an external
interrupt which begins at location 0x500) and the PIT interrupt off of
location 0x1000. I don't see any real handler installed for Machine
Check or Program. I would assume these might be caught by a default
spurious handler but the "blrl" at irq_stub.S:150 branches to location 0
which just results in another Program exception.
The first Machine Check interrupt that gets the whole process going
stores in register SRR2 the value 0x5938 which is supposed to be the bus
error location. Location 0x5938 is actually an instruction in irq_stub.S
(part of _IRQ_Handler) but I don't see a problem there and putting a
breakpoint before location 0x5938 never hits before the first Machine
Check at 0x200.
One other observation: In old_exception_processing/cpu.c:508 where the
actual stwu_r1 value is compared to a template value they do appear to
be equal but for some reason the else condition is taken and
*old_handler is set to zero. This appears to be a possible compiler
error. (I am checking this with no optimization -O0 in powerpc-rtems-gcc.)
If anyone has an understanding of this code I would appreciate any
suggestions as to what is going wrong.
Thanks,
-gene
P/S: I can step through the code and see what is happening using the
Macraigor JTAG debugger with gdb/insight.
Please reply to list.
