Importance of Bochs (and PearPC)
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Oct 18 18:45:01 UTC 2004
I just wanted to reiterate the importance of Bochs and PearPC
to RTEMS.  Right now, each RTEMS user/developer has access to
a limited set of test platforms.  Often those platforms
have no networking, disk storage, or graphics at all.
As Ralf and I spoke about in Munich, the use of Bochs gives
everyone a common high capability reference platform that is
easy to use.
In that light, I am begging for some help here to get it
going.
+  If you have knowledge of the ATA subsystem,
    please give Bochs a try for the File IO test and
    post the complete setup.
+ If you have networking experience with RTEMS, try
   to setup the NE2000 simulation in Bochs with
   RTEMS.  Again post the complete setup.
PearPC has similar capabilities but RTEMS will likely need a
special BSP for it.  But it brings similar capabilities on
a PowerPC.
Please, please take a stab at the above and post results.
I am looking forward to the day where the RTEMS webserver can
be run in a virtual PC and be demonstrated serving files from
the virtual hard disk. :)
It would also be an ideal platform to work on an ISO9660 filesystem,
port a small web client, etc, etc.
Please, please. :)
