Timing of events in an ISR
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Wed Oct 20 14:25:26 UTC 2004
Bruce Robinson writes:
 > Hi Mark,
 > Is your code built for mips1 or mips3? If it's mips3, I found a problem
 > today in the MIPS status register code that you might want to consider.
 > In RTEMS the default Idle task is created with all interrupts enabled. This
 > was allowing undesirable interrupts to occur on my MIPS evaluation board. I
 > made some changes in the _Thread_Create_idle function to set a non-zero
 > interrupt level in the idle task. This should have resulted in the status
 > register being set to only have specified interrupts enabled.
 > The code didn't run and I discovered that all interrupts were disabled in
 > the idle task. After some time I found what appears to be a flaw in the
 > _CPU_ISR_Set_level function in cpu.c. The following statement:
 >   sr = srbits | ((new_level==0)? (0xfc00 | SR_EXL | SR_IE): \
 > 		 (((new_level<<9) & 0xfc00) | \
 > 		  (new_level & 1)?(SR_EXL | SR_IE):0));
 > is missing a set of parentheses on the last line. The '|' has precedence
 > over the '?:' operator. I changed the code to the following and everything
 > worked fine:
 > 		  ((new_level & 1)?(SR_EXL | SR_IE):0)));
 > A similar statement in the macro _CPU_Context_Initialize in cpu.h appears to
 > be correct:
 > 	(_the_context)->c0_sr = ((_intlvl==0)?(0xFF00 | _INTON):( ((_intlvl<<9) &
 > 0xfc00) | \
 > 						       0x300 | \
 > 						       ((_intlvl & 1)?_INTON:0)) ) | \
 > 				SR_CU0 | ((_is_fp)?SR_CU1:0) | _EXTRABITS;
 > This may not be an issue if your using the default interrupt level of 0, but
 > you may run in to this problem if you try setting it to a non-zero value.
Interesting- this problem was found and was supposed to have been
patched some time ago.  I wonder if a MIPS patch got skipped at some
point.  Are you using the latest 4.6?
Gregm
