Wiki Accounts
Angelo Fraietta
afraiett at bigpond.net.au
Mon Oct 18 23:22:39 UTC 2004
Can someone give me very simple instructions on how to sign in to Wiki?
I must be doing something wrong because I cannot get in
Joel Sherrill wrote:
> Angelo Fraietta wrote:
>> I am unable to log in at all
>> I get the following error
>> lib/WikiUserNew.php:2009: Warning[512]: Unable to connect to IMAP
>> server localhost:143/imap/notls
> Are you trying to get a password? Don't bother, it doesn't work.
>>> Ralf Corsepius wrote:
>>>> On Tue, 2004-09-28 at 00:53, Aaron J. Grier wrote:
>>>>> On Mon, Sep 27, 2004 at 06:15:55PM +0200, Ralf Corsepius wrote:
>>>>>> On Mon, 2004-09-27 at 17:30, Joel Sherrill wrote:
>>>>>>> I was wrong. You can add yourself a personal page/account.
>>>>>> How? Detailed instructions, please.
>>>>>> ATM, to me, this Wiki appears to be plain simple non-functional.
>>>>> * go to http://www.rtems.com/phpwiki/ .
>>>>> * in the bottom right corner next to the "sign in as" button, put
>>>>> your
>>>>> desired username and click the "sign in as" button.
>>>>> * the main page will reload again, this time it will say
>>>>> "authenticated
>>>>> as UserName" at the bottom. there will be a question mark next
>>>>> to the
>>>>> username. click on the question mark and fill out the profile page.
>>>> Thanks, however, this is exactly what I did and what only seems to be
>>>> working at random for me.
>>>> I have filed screenshots of 2 failing attempts to RTEMS bug database.
>>>> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=685
>>>> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&cmd=view&pr=684
>>> I think the trick is to create your personal page as soon as you log
>>> in.
>>> If you leave without one, it appears to be hard to get back in.
>>> What I am doing is "Finding" your PersonalPage. It doesn't exist, so
>>> I create it with some dummy modification, then check that I can
>>> login as you and it has always worked (so far).
>>> What is really happening I don't know.
>>>>> * once you are logged in you can change your password by clicking on
>>>>> "Preferences" at the top of any page.
>>>> When I manage to "sign in" (I can sign-in using an account which,
>>>> AFAICT
>>>> Joel has created manually) PhpWiki replies:
>>>> Password cannot be changed. No changes.
>>> There really is no password system enabled in our installation.
>>> PhpWiki appears to support various password schemes but so far I
>>> can't make any of them work. When I do figure it out, I will go
>>> through and assign all
>>> users a password and email it to you.
>>>> Ralf
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
