Can we run RTEMS under AT91SAM7S256?
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Thu Oct 21 03:19:33 UTC 2004
On Thu, Oct 21, 2004 at 11:02:30AM +0800, Yanjun Luo wrote:
> Because of RAM's issue, Linux can't run(or almost can't run).
> Does RTEMS can do that?
I doubt you could get RTEMS to fit in the smallest device (8K RAM /
32K Flash). It might be possible to fit it in the second smallest (16K
RAM / 64K).
The larger devices (32K+ RAM / 128K+ Flash) should work, albeit with
small applications. For comparison, here's the output of arm-rtems-size
for hello and ticker on the edb7312:
text data bss dec hex filename
87391 2816 20992 111199 1b25f arm-rtems/edb7312/samples/hello.exe
114215 2868 20736 137819 21a5b arm-rtems/edb7312/samples/ticker.exe
I'm sure those could be reduced some with effort.
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20041020/3839261e/attachment.bin>
