stdc++ (cout) problem with RTEMS on Sparc emulator
Courtney B. Duncan courtney.b.duncan at jpl.nasa.gov
Thu Oct 21 23:39:48 UTC 2004
I am developing code for a Sparc V7 which uses RTEMS and running it
on a freeware emulator
(see http://www.estec.esa.nl/wsmwww/erc32/freesoft.html )
Everything in the development environment for C and C++ works when
built with RTEMS.  I'm able to do mathematical calculations, view
outputs via printf(), build abstract and derived classes that work,
and so forth, as expected.  The compiler is a backend to GNU C++,
'sparc-rtems-gcc'.
When I try to use cout, linking in -lstdc++, the build grows by about
60K (which should be fine) and the emulator stops on an undefined
instruction before anything else happens.  I have not been able to
find other methods in libstdc++ that I need which don't also pull in
cout and ostream operator<<(), etc., so I'm not able to tell if this
is just a problem with iostream or the entire library.  Attempting to
use vector<double> leads to the same UI stop, for example.
A colleague thought that RTEMS might not yet be robust in this area,
for instance, there might be some processor specific code in some
iostream related routines.
The questions are:  Am I on the right track in tracking down this
problem?  Does C++ cout work for anybody under RTEMS?  Isn't there a
printf() based cout implementation that ought to work in this
situation?
courtney.duncan at jpl.nasa.gov
818-354-8336
M/S 301-125L
"We can lick gravity but sometimes the paperwork is overwhelming."
Dr. Wernher von Braun, circa 1957.
