error 105
Till Straumann
strauman at slac.stanford.edu
Fri Oct 1 14:43:12 UTC 2004
Steve Holle wrote:
> I increased the value in my linkcmds file as follows :
> /* running out of heap, doubling from 0x80000 to 0x100000 */
> _HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x100000;
> Is that the correct way to do it?
Didn't test this but it looks OK - you should then be able to provide
"-Wl,--defsym,_HeapSize=xxxxxx" down to the linker in order to override the
default...
-- T.
> At 05:03 AM 10/1/2004, Joel Sherrill <joel at OARcorp.com> wrote:
>> I recall that much of that memory comes from the C Program Heap
>> so make sure that you have plenty of memory assigned to it.
>> It's early and I am still packing so I hope I got that right. :)
>> --joel
>> Steve Holle wrote:
>>> I increased mbuf capacity and cluster to the values show below and
>>> the same problem occured.
>>> struct rtems_bsdnet_config rtems_bsdnet_config =
>>> &netdriver_config,
>>> #if (defined (RTEMS_USE_BOOTP))
>>> rtems_bsdnet_do_bootp,
>>> 75,
>>> 265*1024, // Expanded mbuf capacity.
>>> 512*1024, // Expanded mbuf cluster capacity.
>>> #else
>>> NULL,
>>> 75,
>>> 0, // Default mbuf capacity.
>>> 0, // Default mbuf cluster capacity.
>>> #endif
>>> // See below for real example
>>> NULL,
>>> // Host name.
>>> NULL,
>>> // Domain name.
>>> NULL,
>>> // Gateway.
>>> NULL,
>>> // Log host.
>>> {NULL},
>>> // Name server(s).
>>> {NULL}
>>> // NTP server(s)
>>> At 03:49 PM 9/30/2004, Chris Johns wrote:
>>>> Steve Holle wrote:
>>>>> I'm trying to get BOOTP running, and when I enable it I get the
>>>>> following :
>>>>> RTEMS: BOOTP call failed -- error 105
>>>>> Where would I find out what error 105 is?
>>>> To find I do:
>>>> $ cd rtems/cpukit
>>>> $ grep -r "BOOTP call failed" *
>>>> libnetworking/nfs/bootp_subr.c: panic("BOOTP call failed -- error
>>>> %d", error);
>>>>> Any idea what's causing it?
>>>> Then looking at the code I see it is an error code from the
>>>> function 'bootpc_call'. Another grep shows this function is in the
>>>> same file, and looks like it is the result of calls to socket type
>>>> functions.
>>>> A look in errno.h gives:
>>>> #define ENOBUFS 105 /* No buffer space available */
>>>> I see 'bootp_call' returns this value if no mbufs are available.
>>>> It your networking code ok ?
>>>> Chris Johns
>>> Steve Holle
>>> Link Communications, Inc.
>>> 1035 Cerise Rd.
>>> Billings, MT 59101
>>> sholle at link-comm.com
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Steve Holle
> 1035 Cerise Rd.
> Billings, MT 59101
