error 105
Steve Holle
sholle at link-comm.com
Fri Oct 1 17:15:25 UTC 2004
Ouch. This is the second time I've shot myself in the foot with this
one. I don't think my changes in the linkcmds file had any effect. We had
the variable in the makefile and I think that was overriding the linkcmds
setting.
I'm running out of feet.
At 08:20 AM 10/1/2004, Brett Swimley wrote:
>You can also do it in your Makefile as:
>AM_LDFLAGS += -Wl,--defsym -Wl,_HeapSize=0x100000
>Brett
>Steve Holle wrote:
>>I increased the value in my linkcmds file as follows :
>>/* running out of heap, doubling from 0x80000 to 0x100000 */
>>_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x100000;
>>Is that the correct way to do it?
>>At 05:03 AM 10/1/2004, Joel Sherrill <joel at OARcorp.com> wrote:
>>>I recall that much of that memory comes from the C Program Heap
>>>so make sure that you have plenty of memory assigned to it.
>>>It's early and I am still packing so I hope I got that right. :)
>>>--joel
>>>Steve Holle wrote:
>>>>I increased mbuf capacity and cluster to the values show below and the
>>>>same problem occured.
>>>> struct rtems_bsdnet_config rtems_bsdnet_config =
>>>> &netdriver_config,
>>>> #if (defined (RTEMS_USE_BOOTP))
>>>> rtems_bsdnet_do_bootp,
>>>> 75,
>>>> 265*1024, // Expanded mbuf capacity.
>>>> 512*1024, // Expanded mbuf cluster capacity.
>>>> #else
>>>> NULL,
>>>> 75,
>>>> 0, // Default mbuf capacity.
>>>> 0, // Default mbuf cluster capacity.
>>>> #endif
>>>> // See below for real example
>>>> NULL,
>>>>// Host name.
>>>> NULL,
>>>>// Domain name.
>>>> NULL,
>>>>// Gateway.
>>>> NULL,
>>>>// Log host.
>>>> {NULL},
>>>>// Name server(s).
>>>> {NULL}
>>>>// NTP server(s)
>>>>At 03:49 PM 9/30/2004, Chris Johns wrote:
>>>>>Steve Holle wrote:
>>>>>>I'm trying to get BOOTP running, and when I enable it I get the
>>>>>>following :
>>>>>>RTEMS: BOOTP call failed -- error 105
>>>>>>Where would I find out what error 105 is?
>>>>>To find I do:
>>>>> $ cd rtems/cpukit
>>>>> $ grep -r "BOOTP call failed" *
>>>>> libnetworking/nfs/bootp_subr.c: panic("BOOTP call failed -- error
>>>>> %d", error);
>>>>>>Any idea what's causing it?
>>>>>Then looking at the code I see it is an error code from the function
>>>>>'bootpc_call'. Another grep shows this function is in the same file,
>>>>>and looks like it is the result of calls to socket type functions.
>>>>>A look in errno.h gives:
>>>>> #define ENOBUFS 105 /* No buffer space available */
>>>>>I see 'bootp_call' returns this value if no mbufs are available.
>>>>>It your networking code ok ?
>>>>> Chris Johns
>>>>Steve Holle
>>>>Link Communications, Inc.
>>>>1035 Cerise Rd.
>>>>Billings, MT 59101
>>>Joel Sherrill, Ph.D. Director of Research & Development
>>>joel at OARcorp.com On-Line Applications Research
>>>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
>>Steve Holle
>>1035 Cerise Rd.
>>Billings, MT 59101
>Brett Swimley
>Sr. Design Engineer
>Advanced Electronic Designs
>406-585-8892
>brett DOT swimley AT aedmt DOT com
Steve Holle
1035 Cerise Rd.
Billings, MT 59101
