Slave Mode on the MC68360
jennifer at oarcorp.com jennifer at oarcorp.com
Mon Oct 4 20:41:28 UTC 2004
Hi Thomas,
It's used on a Radsone EP1A which has a Power PC MPC8245 with a QSPANII to
provide the interface between the PCI bus and the 68360.  I pulled the
68360 console code over a few months ago, but am just getting around to
looking at it again.  At the current time my processor is locking up
somewhere in the serial initialization, but I suspect that is a memory
map issue (my map has changed several times in the past few months).
I just wanted to probe the list to see if anyone else  had used slave mode, to
see if there were any hidden obstacles.
Thanks
Jennifer
Quoting Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
> Hi Jennifer,
> I used the gen360 BSP on a 68040/68360 combination,
> and it works fine. What configuration do you
> actually have? What problems do you see?
> wkr,
> Thomas Doerfler.
> > Has anyone utilized the serial ports on a mc68360 running in
> > slave mode?  I am using the gen68360 bsp console driver as
> > a basis for doing this and wondered if anyone out there had already
> > went through the process.
> > Thanks
> > Jennifer
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
