Slave Mode on the MC68360
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Mon Oct 4 20:53:08 UTC 2004
Hi Jennifer,
if you have any questions about the '360, please let
me know. I used to work with this chip rather often
and also gave training for that chip, so maybe I can
help you if you get stuck somewhere.
Thomas.
> Hi Thomas,
> It's used on a Radsone EP1A which has a Power PC MPC8245 with a QSPANII to
> provide the interface between the PCI bus and the 68360.  I pulled the
> 68360 console code over a few months ago, but am just getting around to
> looking at it again.  At the current time my processor is locking up
> somewhere in the serial initialization, but I suspect that is a memory
> map issue (my map has changed several times in the past few months).
> I just wanted to probe the list to see if anyone else  had used slave mode, to
> see if there were any hidden obstacles.
> Thanks
> Jennifer
> Quoting Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
> > Hi Jennifer,
> > I used the gen360 BSP on a 68040/68360 combination,
> > and it works fine. What configuration do you
> > actually have? What problems do you see?
> > wkr,
> > Thomas Doerfler.
> > > Has anyone utilized the serial ports on a mc68360 running in
> > > slave mode?  I am using the gen68360 bsp console driver as
> > > a basis for doing this and wondered if anyone out there had already
> > > went through the process.
> > > Thanks
> > > Jennifer
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler           Herbststrasse 8
> > D-82178 Puchheim          Germany
> > email:    Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-
> > systems.de/pgp_keys.htm
