Putting debug info in rtems files
Smith, Gene
gene.smith at siemens.com
Mon Oct 11 12:44:13 UTC 2004
Thomas Doerfler wrote, On 10/11/2004 1:24 AM:
> Gene,
> when RTEMS libraries get built, nested makefiles are
> executed that "walk" through the build directory
> structure. Therefore, each file is compiled from a
> certain point in the build directory structure that
> lies in paralllel to the source directory structure.
Yeah, that's what I finally figured out too *after* I posted. It's based
on the "build-rtems" directory structure.
> Consequeces:
> - You have more or less of these "dots" depending on
> how deep the corresponding directory is inside the
> build tree. Just an idea: You might come around
> this, if you call the initial "configure" not in a
> relative way (e.g. "../rtems-4.6.0/configure", but
> in an absolute way, e.g.
> "/usr/local/src/rtems/tools/rtems-4.6.0/configure").
That sounds promising. Thanks.
> - There is no common location, from which the source
> file pointers in the debug info is correct for all
> object files.
> wkr,
> Thomas.
>>Kamen Penev wrote, On 10/08/2004 08:47 PM:
>>>My intuition is this is a linker problem. Check your linker script and
>>>the invocation of the linker. Make sure you are not throwing away the
>>>stabs sections.
>>>Kamen
>>My linkcmds file (based on helas403) does call out the stab sections (as
>>well as dwarfs).
>>I noticed that when I run gdb (via insight) I can actually see my source
>>if I set my gdb source "directory" path just right. This seems to be
>>because there are a lot of "../" constructs in the hello.exe file. For
>>example I see things like this where source files appear in the binary:
>>../../../../../../rtems-4.6.1/cpukit/libcsupport/src/malloc.c
>>../../../../../rtems-4.6.1/c/src/optman/rtems/no-dpmem.c
>>../../../../../../../../../rtems-4.6.1/c/src/lib/libcpu/powerpc/ppc403/console/console405.c
>>I see the same things when files are entered when running gdb.
>>The number of ../'s seem to depend on something since they vary with
>>file but not sure what. Any idea what controls this? (I have to set my
>>"directory" possibly 9, 5, 6 levels beyond the "rtems-4.6.1" to see my
>>source in gdb.)
>>If the ../'s weren't there, I could set my gdb directory to right before
>>the "rtems-4.6.1" and gdb would append to that the correct file path.
>>Anyone know what is going on here and if it is possible to get rid of
>>the ../'s?
>>-gene
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
