Bochs users out there?
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Oct 12 21:42:41 UTC 2004
Erwin Rol wrote:
> On Tue, 2004-10-12 at 13:47 -0500, Joel Sherrill wrote:
>>Hi,
>>I would like to get a current set of instructions for running
>>RTEMS under Bochs. If anyone out there is doing it, please
>>respond on the list with help. :)
> A long time ago (like 3 years or more) I used it, and booted RTEMS with
> a hacked linux kernel boot code, there might even be some mails in the
> archive on how i did it. I don't have anything left from that time
> (which is about 3 employers back).
I searched the list and saw your posts. :-) There is something (a patch
to Bochs I think) attached to one of the posts. Do you have any
recollection if it got merged?
Did the NIC in the simulator work with the RTEMS BSP?
I know it was a long time ago but what do you remember about it?
Good points, problems, pitfalls, etc?
Ralf and I talked last week and he independently mentioned getting
Bochs to run so we coudl test easily. I have long wanted to have
it running but never got a clear idea on what was required and what
capabilities were expected to work. I am fishing now to try to
get good instructions and advice. :)
> And what about PearPC http://pearpc.sourceforge.net/ ? I actually
> managed to install OS/X on it without problems, so powerpc-rtems should
> work too I guess ?
Possibly but for now, psim is sufficient for most powerpc testing
on a simulator. It would be nice I suppose if the network driver
in PearPC worked with RTEMS.
>>Thanks.
> OK not a real answer, but maybe you can find something useful in the
> list archives searching for my name.
> - Erwin
joel at OARcorp.com On-Line Applications Research
