Bochs users out there?
Zhang Zhichao-A5057C
A5057C at motorola.com
Wed Oct 13 04:35:39 UTC 2004
I used it(version 1, 2) last year, and can boot RTEMS(4.5.0, 4.6.1)
with GRUB (0.96??). manipulate the image file with winimage.
And can run nearly all the test program under
(\c\src\tests\samples,\c\src\tests\sptests,\c\src\tests\tmtests)
But I failed to enable Bochs's ne2000 NIC with WINPCAP.
-----Original Message-----
From: joel.sherrill at OARcorp.com [mailto:joel.sherrill at OARcorp.com]
Sent: Wednesday, October 13, 2004 5:43 AM
To: Erwin Rol
Cc: rtems-users at rtems.com
Subject: Re: Bochs users out there?
Erwin Rol wrote:
> On Tue, 2004-10-12 at 13:47 -0500, Joel Sherrill wrote:
>>Hi,
>>I would like to get a current set of instructions for running RTEMS
>>under Bochs. If anyone out there is doing it, please respond on the
>>list with help. :)
> A long time ago (like 3 years or more) I used it, and booted RTEMS
> with a hacked linux kernel boot code, there might even be some mails
> in the archive on how i did it. I don't have anything left from that
> time (which is about 3 employers back).
I searched the list and saw your posts. :-) There is something (a patch to Bochs I think) attached to one of the posts. Do you have any recollection if it got merged?
Did the NIC in the simulator work with the RTEMS BSP?
I know it was a long time ago but what do you remember about it? Good points, problems, pitfalls, etc?
Ralf and I talked last week and he independently mentioned getting Bochs to run so we coudl test easily. I have long wanted to have it running but never got a clear idea on what was required and what capabilities were expected to work. I am fishing now to try to get good instructions and advice. :)
> And what about PearPC http://pearpc.sourceforge.net/ ? I actually
> managed to install OS/X on it without problems, so powerpc-rtems
> should work too I guess ?
Possibly but for now, psim is sufficient for most powerpc testing on a simulator. It would be nice I suppose if the network driver in PearPC worked with RTEMS.
>>Thanks.
> OK not a real answer, but maybe you can find something useful in the
> list archives searching for my name.
> - Erwin
joel at OARcorp.com On-Line Applications Research
