Memory leak after C++ exception
Till Straumann
strauman at slac.stanford.edu
Fri Oct 15 16:28:09 UTC 2004
Nice catch, Joel.
T.
Joel Sherrill wrote:
> Valery Pykhtin wrote:
>> My version is 4.6.0pre5. Ok I understand, will download new RTEMS on
>> monday.
> You can login to GNATS as guest/guest and just grab that one patch
> if you like.
>> Thank you very much,
> At this point, I am just glad it was a known problem that I
> recognized. :)
> It is interesting that code runs for years and then you
> improve it and break it. This failure is a side-effect of
> modifications to RTEMS memory allocation critical section
> management to improve context switch latency.
> --joel
>> Valery
>>> What RTEMS version is this? This looks very much like this PR
>>> 2003-11-26 Joel Sherrill <joel at OARcorp.com>
>>> PR 523/filesystem
>>> * src/malloc.c: Make malloc family safer for use from ISRs and
>>> dispatching critical sections. If in a critical section while
>>> doing a free(), then the free is deferred until the next
>>> malloc() attempt.
>>> From what I can tell, it would have been fixed in 4.6.0 but not
>>> pre5.
>>> --joel
