I have Bochs Working enough to boot floppy!!
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Sat Oct 16 21:47:28 UTC 2004
Chris Caudle wrote:
> I posted these instructions a couple of years back when I first was playing
> with Bochs and RTEMS. Here is the mailing list reference, and the text is
> also copied below for convenience.
> http://www.rtems.com/rtems/maillistArchives/rtems-users/2002/december/msg00051.html
> Would these still be relevent enough that I should add them to the Wiki?
> Mostly it covers how you use the loop interface to mount a floppy disk image
> so that you can modify the disk image before you start the simulator.
> This does not involve mtools, and I haven't looked over the details of the
> mtools instructions posted a few days ago to know whether the process I
> describe would be exclusionary or complementary to the mtools method.
> Comments?
Please correct/enhance the Wiki Bochs entry as you see fit.
If you know how to use the network interface or hard disk
with RTEMS and Bochs, please share that also. :)
