I have Bochs Working enough to boot floppy!!
Erwin Rol
mailinglists at erwinrol.com
Mon Oct 18 08:52:35 UTC 2004
Hey all,
Sorry for the slow reply, but i had other things to do :-)
On Wed, 2004-10-13 at 10:03 -0500, Joel Sherrill wrote:
> Hi All,
> I have a Bochs configuration file that works enough to run the 4.5.0
> grub floppy image. I just ran it as "bochs -f b -q".
I boot RTEMS from CDROM (ISO image to be exact). What i do is just dump
a bunch of RTEMS .exe files in a directory, add grub , use mkisofs to
generate a CD and boot from that CD. Since the CD is small mkisofs is
done in a second or two. The advantage is that you don't need calculate
the size of the image, and are not limited to the size of a floppy.
To make a grub bootable CD just follow the GRUB manual
http://www.gnu.org/software/grub/manual/html_node/Making-a-GRUB-bootable-CD-ROM.html
If you don't make a "menu" for bochs you just have to type :
kernel (cd)/hello.exe
boot
at the bochs prompt (of course hello.exe must be in the CD root path).
> Anyone have an idea what CPU model is being simulated by default
> and which other variants can be tested using different Bochs options?
pentium, the pentium pro support is still incomplete, at least thats
what the bochs website says. You can change the CPU type when compiling
bochs.
> How about simulating a hard disk? Anyone done that with RTEMS?
didn't try
> Erwin.. did you get the TCP/IP stack working?
Also didn't try that.
> I would really like to get to the point where this is an easy
> way to test nearly all of RTEMS.
with a bit of scripting it should be easy to make the CD-image and than
automatically start bochs with that image. that way you could for
example type "rtems_bochs hello.exe" and that would generate a bootable
CD with hello.exe and start bochs.
Years back I hacked a GDBstub-proxy for bochs, that worked by passing
the serial port reads to a socked, and so a GDB from outside bochs could
contact the gdbstub in rtems that was running in bochs. This is not
needed anymore, bochs has a real gdbstub build in now ( --enable-gdbstub
when compiling bochs) with that you can connect a gdb to bochs and debug
the program that runs in bochs.
> Erwin.. then maybe someone can do the same for PearPC. :)
maybe it is an idea to make a BOCHS BSP (and PearPC BSP) in rtems, so
that hardware drivers and maybe special hacks to work around problems
can be put there ?
- Erwin
# configuration file generated by Bochs
config_interface: textconfig
display_library: x
megs: 64
romimage: file=/usr/share/bochs/BIOS-bochs-latest, address=0xf0000
vgaromimage: /usr/share/bochs/VGABIOS-elpin-2.40
boot: cdrom
# no floppya
# no floppyb
ata0: enabled=1, ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
ata0-master: type=cdrom, path="/home/erwin/rtems.iso", status=inserted, biosdetect=auto, model="Generic 1234"
ata1: enabled=0
ata2: enabled=0
ata3: enabled=0
parport1: enabled=0
com1: enabled=0
usb1: enabled=0
# no sb16
floppy_bootsig_check: disabled=0
vga_update_interval: 30000
keyboard_serial_delay: 20000
keyboard_paste_delay: 100000
floppy_command_delay: 50000
ips: 500000
text_snapshot_check: 0
mouse: enabled=0
private_colormap: enabled=0
i440fxsupport: enabled=0
clock: sync=none, time0=local
# no ne2k
newharddrivesupport: enabled=1
# no loader
log: -
logprefix: %t%e%d
debugger_log: -
panic: action=fatal
error: action=report
info: action=report
debug: action=ignore
pass: action=fatal
keyboard_mapping: enabled=1, map=/usr/share/bochs/keymaps/x11-pc-de.map
keyboard_type: mf
user_shortcut: keys=none
gdbstub_port: 1234
# no cmosimage
