Timing of events in an ISR
Mark VanderVoord
markvandervoord at yahoo.com
Tue Oct 19 18:41:35 UTC 2004
--- "Joel Sherrill <joel at OARcorp.com>"
<joel.sherrill at OARcorp.com> wrote:
> Can you verify that the task's do indeed have
> interrupts
> enabled AFTER the 1st interrupt occurs? Random
> thought
> ... if the ISR return path may not be restoring
> interrupt
> level correctly, it could accidentally disable
> interrupts
> in the interrupted thread. Just periodically check
> the
> disable level in the threads.
I've added a request for the task mode before and
after the interrupt setup. It is 127 in both places,
even the first time it is run! (It should be 0
because I am running with RTEMS_DEFAULT_MODES). I
also checked at the very start of the routine. It is
also 127 here!
I've added a routine to set the mode from within the
task to 0, then immediately check it. It's again 127.
This is true even if I do not initialize the SPI ISR
to run.
I have never attempted to compile rtems before this
point, but it looks like that is my only option at
this point?
Mark S VanderVoord
Self-Guided Systems, LLC
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
