Ticker problem on ppc405 - FIXED
Smith, Gene gene.smith at siemens.com
Wed Oct 20 16:32:57 UTC 2004
Ralf Corsepius wrote, On 10/20/2004 10:49 AM:
<big snip>
>>Just add
>>#define <bsp.h>
> Yes, cf. PR 696
> http://www.rtems.org/cgi-bin/gnatsweb.pl?debug=&database=RTEMS&cmd=view+audit-trail&cmd=view&pr=696
How do you get a uid/pw to enter bugs or comments here?
(guest seems to work for read-only)
>>>To let bspopts.h contain it, you have to add the corresponding
>>>configure-script magic to your BSP's configure.ac
>>>(cf. c/src/lib/libbsp/powerpc/helas403/configure.ac) and then to run
>>configure.ac here already contains line:
>>RTEMS_BSPOPTS_SET([PPC_USE_SPRG],[*],[1])
>>Is this the "magic" for defining it to 1?
> Not quite, it is the magic to let it default to 1.
> You can override it when invoking the configure script via an
> environment variable.
So if I want PPC_USE_SPRG to zero in bspopts.h I could do something like:
$ export PPC_USE_SPRG=0
$ ../configure ......
$ make all
>>Is the above magic what causes bspopts.h to contain:
>>#define PPC_USE_SPRG 1
> Yes.
>>Why does <BSP>/include/bspopts.h.in contain
>>#undef PPC_USE_SPRG
> This file is an "autoheader", i.e. it is automatically generated by
> autoheader reading configure.ac as input file.
> bspopts.h.in later is used as input template for generating bspopts.h
> when running the configure script.
> Ralf
