Timing of events in an ISR
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Wed Oct 20 13:49:29 UTC 2004
Mark VanderVoord wrote:
> I've discovered something which I think supports
> Joel's theory about the problem.
> In the spi task (TA1 in the sample files in the last
> attachment), if I replace
> rtems_event_receive(1,RTEMS_WAIT|RTEMS_EVENT_ALL,0,&temp);
> with
> while
> (rtems_event_receive(1,RTEMS_NO_WAIT|RTEMS_EVENT_ALL,0,&temp));
> the response time drops to less than 10 usec (which is
> what I was originally expecting). At first I thought
> this disagreed with my previous results, as I have
> already shown that the delay was occuring before the
> ISR was called.
> Then I realized that this seems to support Joel's idea
> that my IDLE thread may have an error which is making
> it non-preemptable until the tick timer goes off. If
> this were the case (but my normal task is ok), then it
> would cause this behavior, right?
> Is there any way I can determine what the IDLE
> thread's mode settings are?
If you are in gdb, then you can print out *_Thread_Idle
and look at the boolean is_preemptible.
But it is more likely that if you broken inside the IDLE
thread that you would see an SR that doesn't allow
your SPI interrupt. It could be a variation on the
MIPS bug mentioned earlier in this thread.
> Mark S VanderVoord
> Self-Guided Systems, LLC
> _______________________________
> Do you Yahoo!?
> Declare Yourself - Register online to vote today!
> http://vote.yahoo.com
joel at OARcorp.com On-Line Applications Research
