Makefiles
Till Straumann
strauman at slac.stanford.edu
Mon Oct 25 16:34:57 UTC 2004
Jay Monkman wrote:
> On Mon, Oct 25, 2004 at 04:42:29PM +0100, James Yates wrote:
>>This is for RTEMS 4.6.0.
>> This would be a nice thing to have on a permanent basis. Inside my
>>makefile I have a CFLAGS+= line.
(I was assuming you are using the template 'Makefile.leaf').
>> When I added -O0 to it, my rtems app
>>seemed to fail to work. I didn't bother investigating this perhaps I
>>should have.
Yes, you should have. I tested 'CFLAGS+= -O0' with one of my applications
and it works fine. Could be that disabling optimization triggers
a bug in your code?
>>Can I then change CFLAGS+= to CFLAGS = and use completely different
>>flags in building the app to when I built RTEMS.
Yes, but you are discouraged to do so [unless you really know
what you are doing]. The BSP might know of vital flags which
must not be omitted.
T.
> Are you using something like the template Makefile.leaf?
> If so, you can modify/overwrite CFLAGS after the lines:
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> include $(RTEMS_CUSTOM)
> include $(RTEMS_ROOT)/make/leaf.cfg
