GDB configure problem
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Oct 29 11:18:07 UTC 2004
Xuemei Zhao wrote:
> Hi, joel. Thanks a lot for your reply.
> My host system is solaris 2.9 on sparc.
> Two definitions of struct bcache are in /usr/include/sys/stream.h:330
> and /gdb5.2/gdb/bcache.h:93
> How can I solve this problem?
Two ideas -- try gdb 5.3 or comment out the offending definition in gdb.
I've had to do this before on cygwin.
--joel
> Thanks again.
> At 06:27 AM 28/10/2004 -0500, you wrote:
>> Xuemei Zhao wrote:
>>> Hi,
>>> I am trying to build GNU tools,
>>> Can I set the parameter --prefix=/home/multiproc/rtems, instead of
>>> --prefix=/opt/rtems?
>>> I met the following error when I configured GDB 5.2. Before that,
>>> I have succeeded to build gcc and binutil.
>> Changing the prefix is perfectly OK and should have absolutely nothing
>> to do with this problem.
>> What host are you on?
>> Where are the two definitions of struct bcache?
>>> gmake[1]: Entering directory `/home/multiproc/tools/b-gdb/gdb'
>>> gcc -c -g -O2 -I/usr/include/v9 -I. -I../../gdb-5.2/gdb
>>> -I../../gdb-5.2/gdb/config -DHAVE_CONFIG_H
>>> -I../../gdb-5.2/gdb/../include/opcode
>>> -I../../gdb-5.2/gdb/../readline/.. -I../bfd
>>> -I../../gdb-5.2/gdb/../bfd -I../../gdb-5.2/gdb/../include -I../intl
>>> -I../../gdb-5.2/gdb/../intl -DMI_OUT=1 -DUI_OUT=1 -Wimplicit
>>> -Wreturn-type -Wcomment -Wtrigraphs -Wformat -Wparentheses
>>> -Wpointer-arith -Wuninitialized ../../gdb-5.2/gdb/ser-unix.c
>>> In file included from /usr/include/netinet/in.h:41,
>>> from /usr/include/sys/socket.h:203,
>>> from ../../gdb-5.2/gdb/ser-unix.c:29:
>>> /usr/include/sys/stream.h:330: redefinition of `struct bcache'
>>> gmake[1]: *** [ser-unix.o] Error 1
>>> gmake[1]: Leaving directory `/home/multiproc/tools/b-gdb/gdb'
>>> gmake: *** [all-gdb] Error 2
>>> what's the problem? How can I solve it?
>>> Any idea?
>>> Thanka a lot.
>>> May
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Xuemei Zhao
> School of Informatics and Engineering
> Engineering Building
> Flinders University,
> Adelaide 5042, S.A.
> Australia.
> Home Phone: (08) 8291 6361
> Office Phone: (08) 8201 5158
