ppc405 dma - vm - cache question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Oct 29 19:56:03 UTC 2004
Kate Feng wrote:
> gregory.menke at gsfc.nasa.gov wrote:
>> Kate Feng writes:
>> > > gregory.menke wrote :
>> > > > Feng, Shuchen writes:
>> > > >> I do not know how well ethernet driver perform with non-cacheable
>> > memory.
>> > > > Please ask this question more specifically.
>> > > Thanks. It was not a question. I meant I did not have to
>> > write the ethernet driver accessing non-cacheable memory.
>> > Thus I do not know the performance.
>> The ethernet hardware and packet buffers must be non-cached, else the
>> cache will interfere with reading and writing the registers as well as
>> the packet buffers.
> I had mentioned in my previous E-mail that I had the buffers in the
> cachable area by turning on the hardware snoop mechanism provided
> by my mvme5500 board for the DMA transfer and other network involved
> activities. This is achieved via the sophisticated system controller
> of the board. I found the 10/100MHZ ethernet of mvme5500 twice
> faster (or sometimes more) than that of mvme2307 by running some
> EPICS network tests. However, I do not have time or need to study the
> code of the motorola_powerpc BSP to find out the cache issue for the
> network driver. Maybe it's easier if you can point out.
> For boards that do not provide hardware snoop, it would
> be interesting to weight between the option of the software snoop in
> RTEMS v.s. the option of the non-cached memory. I thought BSD software
> deals with the software snoop option via the software routines Gene
> Smith pointed out in his original message.
> bus_dmamap_create();
> bus_dmamem_alloc();
> bus_dmamap_load();
> bus_dmamap_sync();
THen it would be the BSPs responsibility to provide the implementation
of these routines with some shared code having default no-op versions.
> Regards,
> Kate
joel at OARcorp.com On-Line Applications Research
