4.6.1 build problems
    rtwas
    rtwas at comcast.net
    Wed Sep  1 04:15:57 UTC 2004
Joel Sherrill <joel at OARcorp.com> wrote:
> This doesn't seem to have enough information.  Did the
> untar finish?
Aparently it did not. I reinstalled the source and the build seems to
work find now
Thanks.
Robert W.
> Did the configure finish successfully?
> Do you have /opt/rtems-4.6/bin at the front of your
> PATH?
> On RH9, this should just work.
> --joel
> rtwas wrote:
>> Hello,
>> I'm running rh9
>> I've installed:
>> rtems-4.6.1.tar
>> rtems-4.6-rtems-base-binutils-2.13.2.1-2.i686.rpm
>> rtems-4.6-i386-rtems-binutils-2.13.2.1-2.i686.rpm
>> rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
>> rtems-4.6-i386-rtems-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
>> rtems-4.6-rtems-base-gdb-5.2-1.i686.rpm
>> rtems-4.6-i386-rtems-gdb-5.2-1.i686.rpm
>> Based on my understanding of the instructions I created a seperate
>> directory ./i386 and
>> using the pc386 HOWTO insructions I cd to ./i386 and run:
>> ../rtems-4.6.1/configure --target=i386-rtems  --enable-rtemsbsp=pc386
>> configurations seems to work ok and it says:
>> 'gmake all' will build the following BSPs: pc386.
>> So I do and it at some point I get:
>> Making all in .
>> gmake[2]: Entering directory
>> `/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c'
>> gmake[2]: Nothing to be done for `all-am'.
>> gmake[2]: Leaving directory
>> Making all in pc386
>> `/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c/pc386'
>> gmake[2]: *** No rule to make target `all'.  Stop.
>> gmake[1]: *** [all-recursive] Error 1
>> gmake[1]: Leaving directory
>> gmake: *** [all-recursive] Error 1
>> Thanks for your help
>> Robert Wasierski
>> ATA
