Q about rtems_timer_fire_after
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Sep 9 13:01:40 UTC 2004
Chris Johns wrote:
> mikeci at acm.org wrote:
>> I have a question about function rtems_timer_fire_after. Can this routine
>> be called in ISR context?
> Yes. Joel and I have just been looking over this code and this call can
> be made while in an ISR.
If your TSR shouldn't be called from an ISR, then you should use
the alternative versions which use a timer server.  See:
   + rtems_timer_server_initiate
   + rtems_timer_server_fire_after
   + rtems_timer_server_fire_when
They were added to support TSRs which cannot be called from ISRs.
