cygwin build_alias issue (and a possible workaround...)
Chris Johns
cjohns at cybertec.com.au
Tue Sep 14 02:29:07 UTC 2004
Bogdan Vacaliuc wrote:
> Thanks for that data point. I guess there is still a deficiency.
> Please try this (since it is easy for you, I think):
I have access to the machine at the moment.
> Add a function using the option=value items from your test-fail script into the test-configure script.
I have and I attach the script for you plus the fail.log (appended
together). Note, all the failing tests on WinME pass on WindowsXP with
MSYS. More below ...
[ Note, I needed to remove some '-' characters from the functions
for the MSYS sh to run the script. ]
> I would expect the failure to occur on the autoconf generated configure more-or-less
> with the same frequency as when you call your test script.
It does. It fails on the first pass on WinME.
> [NOTE: I had to remove all (3?!) references to --srcdir=, but other than that it's the
> same as your command line in test-fail]
> I have observed sensitivity to kind and quantity of arguments as well; perhaps the
> build system stirs in additional entropy?
I agree. I have added a number of new tests I hope will narrow the
failure down:
ccjfail
This is the command line in the nested configure that fails for
me on WinME and MSYS.
ccjminfail
I removed the options starting at the first until the fail did not
occur. Less than 4 '--' type options and the failure stopped. More
did not seem to change the result as ccjfail shows.
ccjmin2fail
The failure with the build_alias variable is created on MSYS on
WinME.
ccjminpass
Removing a '--' type option stopped the failure.
ccjmin2pass
Same as ccjminpass except the build_alias parameter this time.
The configure script's option handling loop is a regexp 'expr' command
to filter the option's arguments then a shell variable assignment for
the '--cache=file=' option, then the failed '--enable-*' option. I
placed the same commands in the 'test-configure' script before calling
configure and there was no failure.
I also found hacking the configure script where the '--enable-*' option
is handled stopped the failure. I added the same call to 'expr', without
an exit code check, that tests for a valid shell script variable.
Basically, this specific regexp 'expr' call seems to fail with expr
returning an error code.
> It
> would be better if we could come up with a list that covers *all* machines
> and environments. Clearly mine is less than that right now.
MSYS on WindowsXP _seems_ fine, while WinME is not. I have no idea why.
Chris Johns
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20040914/fc29112f/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20040914/fc29112f/attachment-0001.ksh>
