cygwin build_alias issue (and a possible workaround...   really this time...)
    Scott Newell
    newell at cei.net
    Wed Sep 15 15:15:24 UTC 2004
Sorry for the delay on my end, had to get some products out the door!
With /bin/bash.exe copied to /bin/sh.exe, the test result is:
   *** CREATE configure.ac ***
   *** GENERATE configure ***
   Running using function ccjfail()...
   *** TEST 0 ***
   *** TEST 0 FAILS ***
   configure: error: invalid feature name: multilib
Running again:
   *** TEST 0 ***
   *** TEST 1 ***
   *** TEST 2 ***
   *** TEST 3 ***
   *** TEST 4 ***
   *** TEST 5 ***
   *** TEST 6 ***
   *** TEST 7 ***
   *** TEST 8 ***
   *** TEST 9 ***
   *** TEST 10 ***
   *** TEST 11 ***
   *** TEST 12 ***
   *** TEST 12 FAILS ***
   configure: error: invalid variable name: build_alias
Once more:
   *** TEST 0 ***
   *** TEST 1 ***
   *** TEST 2 ***
   *** TEST 3 ***
   *** TEST 4 ***
   *** TEST 5 ***
   *** TEST 6 ***
   *** TEST 7 ***
   *** TEST 8 ***
   *** TEST 9 ***
   *** TEST 10 ***
   *** TEST 11 ***
   *** TEST 12 ***
   *** TEST 13 ***
   *** TEST 13 FAILS ***
Trying with /bin/ash.exe copied to /bin/sh.exe:
   *** TEST 0 ***
   *** TEST 1 ***
   *** TEST 2 ***
   *** TEST 3 ***
   *** TEST 4 ***
   *** TEST 5 ***
   *** TEST 6 ***
   *** TEST 7 ***
   *** TEST 8 ***
   *** TEST 9 ***
   *** TEST 9 FAILS ***
Again:
   *** TEST 0 ***
   *** TEST 1 ***
   *** TEST 2 ***
   *** TEST 3 ***
   *** TEST 4 ***
   *** TEST 5 ***
   *** TEST 6 ***
   *** TEST 7 ***
   *** TEST 8 ***
   *** TEST 9 ***
Once more:
   *** TEST 0 ***
   *** TEST 1 ***
   *** TEST 2 ***
   *** TEST 3 ***
   *** TEST 4 ***
   *** TEST 5 ***
   *** TEST 6 ***
   *** TEST 7 ***
   *** TEST 8 ***
   *** TEST 9 ***
   *** TEST 10 ***
   *** TEST 11 ***
   *** TEST 12 ***
   *** TEST 13 ***
   *** TEST 14 ***
   *** TEST 15 ***
   *** TEST 16 ***
   *** TEST 16 FAILS ***
Here's the cygcheck -c output:
   Cygwin Package Information
   Package                 Version            Status
   _update-info-dir        00227-1            OK
   ash                     20040127-1         OK
   autoconf                2.59-1             OK
   autoconf-devel          2.59-1             OK
   autoconf-stable         2.13-5             OK
   automake                1.7.9-1            OK
   automake-devel          1.8.5-1            OK
   automake-stable         1.4p6-2            OK
   base-files              3.0-3              OK
   base-passwd             1.1-1              OK
   bash                    2.05b-16           OK
   bc                      1.06-1             OK
   binutils                20040725-2         OK
   bison                   20030307-1         OK
   byacc                   1.9-1              OK
   bzip2                   1.0.2-5            OK
   check                   0.8.4-1            OK
   clear                   1.0-1              OK
   clisp                   2.33.1-1           OK
   cmake                   2.0.3-1            OK
   cpio                    2.5-3              OK
   crypt                   1.1-1              OK
   ctags                   5.5-4              OK
   cvs                     1.11.6-3           OK
   cygipc                  2.03-2             OK
   cygutils                1.2.5-1            OK
   cygwin                  1.5.10-3           OK
   dejagnu                 20021217-2         OK
   diffutils               2.8.7-1            OK
   editrights              1.01-1             OK
   ELFIO                   1.0.0-1            OK
   emacs                   21.2-13            OK
   emacs-X11               21.2-13            OK
   expat                   1.95.7-1           OK
   expect                  20030128-1         OK
   file                    4.09-1             OK
   fileutils               4.1-2              OK
   findutils               4.1.7-4            OK
   flex                    2.5.4a-3           OK
   fontconfig              2.2.2-1            OK
   fortune                 1.8-2              OK
   freetype2               2.1.5-1            OK
   gawk                    3.1.4-3            OK
   gcc                     3.3.3-3            OK
   gcc-core                3.3.3-3            OK
   gcc-g++                 3.3.3-3            OK
   gcc-mingw               20040810-1         OK
   gcc-mingw-core          20040810-1         OK
   gcc-mingw-g++           20040810-1         OK
   gdb                     20030919-1         OK
   gdbm                    1.8.3-7            OK
   gettext                 0.14.1-1           OK
   gmp                     4.1.2-1            Incomplete
   gperf                   2.7.2-1            OK
   grep                    2.5-1              OK
   groff                   1.18.1-2           OK
   gzip                    1.3.5-1            OK
   indent                  2.2.9-1            OK
   ioperm                  0.4-1              OK
   less                    381-1              OK
   libbz2_1                1.0.2-5            OK
   libdb3.1                3.1.17-2           OK
   libdb4.2                4.2.52-1           OK
   libfontconfig1          2.2.2-1            OK
   libfreetype26           2.1.5-1            OK
   libgdbm                 1.8.0-5            OK
   libgdbm-devel           1.8.3-7            OK
   libgdbm3                1.8.3-3            OK
   libgdbm4                1.8.3-7            OK
   libgettextpo0           0.14.1-1           OK
   libiconv2               1.9.2-1            OK
   libintl                 0.10.38-3          OK
   libintl1                0.10.40-1          OK
   libintl2                0.12.1-3           OK
   libintl3                0.14.1-1           OK
   libjpeg62               6b-11              OK
   libjpeg6b               6b-8               OK
   libncurses5             5.2-1              OK
   libncurses6             5.2-8              OK
   libncurses7             5.3-4              OK
   libpcre                 4.1-1              OK
   libpcre0                4.5-1              OK
   libpng12                1.2.5-4            OK
   libpopt0                1.6.4-4            OK
   libreadline4            4.1-2              OK
   libreadline5            4.3-5              OK
   libtiff3                3.6.0-2            OK
   libtiff4                3.6.0-5            OK
   libungif                4.1.0-3            OK
   libXft                  2.1.6-1            OK
   libXft1                 1.0.0-1            OK
   libXft2                 2.1.6-1            OK
   login                   1.9-7              OK
   lynx                    2.8.4-8            OK
   m4                      1.4-1              OK
   make                    3.80-1             OK
   man                     1.5k-3             OK
   mingw-runtime           3.3-1              OK
   minires                 0.97-1             OK
   mktemp                  1.5-3              OK
   more                    2.11o-1            OK
   nano                    1.2.2-1            OK
   ncurses                 5.3-4              OK
   openssh                 3.9p1-1            OK
   openssl                 0.9.7d-1           OK
   openssl096              0.9.6j-1           OK
   patch                   2.5.8-8            OK
   patchutils              0.2.30pre1-1       OK
   pcre                    4.5-1              OK
   pcre-doc                4.5-1              OK
   perl                    5.8.5-3            OK
   pilrc                   3.1                OK
   prc-tools               2.3                OK
   prc-tools-htmldocs      2.3                OK
   python                  2.3.4-2            OK
   readline                4.3-5              OK
   rsync                   2.6.2-2            OK
   ruby                    1.8.1-1            OK
   rxvt                    2.7.10-4           OK
   sed                     4.1.2-1            OK
   sh-utils                2.0.15-4           OK
   sharutils               4.2.1-3            OK
   splint                  3.1.1-1            OK
   tar                     1.13.25-5          OK
   tcltk                   20030901-1         OK
   tcsh                    6.13.00-2          OK
   termcap                 20021106-2         OK
   terminfo                5.3_20030726-1     OK
   texinfo                 4.2-4              OK
   textutils               2.0.21-1           OK
   time                    1.7-1              OK
   unzip                   5.50-5             OK
   w32api                  2.5-1              OK
   wget                    1.9.1-1            OK
   which                   1.5-2              OK
   whois                   4.6.14-1           OK
   X-startup-scripts       1.0.8-1            OK
   Xaw3d                   1.5D-5             OK
   XFree86-base            4.3.0-11           OK
   XFree86-bin             4.3.0-21           OK
   XFree86-etc             4.3.0-12           OK
   XFree86-fenc            4.3.0-2            OK
   XFree86-fnts            4.3.0-2            OK
   XFree86-lib             4.3.0-3            OK
   XFree86-lib-compat      4.3.0-2            OK
   XFree86-startup-scripts 4.3.0-1            OK
   XFree86-xserv           4.3.0-68           OK
   xorg-x11-base           6.7.0.0-8          OK
   xorg-x11-bin            6.7.0.0-4          OK
   xorg-x11-bin-dlls       6.7.0.0-5          OK
   xorg-x11-bin-lndir      6.7.0.0-2          OK
   xorg-x11-etc            6.7.0.0-3          OK
   xorg-x11-fenc           6.7.0.0-2          OK
   xorg-x11-fnts           6.7.0.0-1          OK
   xorg-x11-libs-data      6.7.0.0-3          OK
   xorg-x11-xwin           6.7.0.0-12         OK
   zip                     2.3-6              OK
   zlib                    1.2.1-1            OK
I'll try to grab the snapshot and test again shortly.
newell
