telnetd
Fernando RUIZ CASAS correo at fernando-ruiz.com
Fri Sep 17 08:27:48 UTC 2004
Hi,
   But you must put attention.
   When the session is closed a delete_task_var in
automatic free when close can crash the memory.
   This is a bad behavior for this option.
See you.
Fernando RUIZ.
On Thu, 16 Sep 2004 12:06:03 -0500
  "Joel Sherrill <joel at OARcorp.com>"
<joel.sherrill at OARcorp.com> wrote:
> Steve Holle wrote:
>> Can anyone tell me how to enable telnetd ?  I've used
>>the same technique
>> I used on the other network functions as shown in the
>>code below :
>>         #ifdef ENABLE_NETWORKING
>>                 std::cout << "  Starting  : Network
>>Initialization..."
>> << std::endl ;
>>                 std::cout.flush() ;
>>           rtems_bsdnet_initialize_network ();
>>                 std::cout << "  Completed : Network
>>Initialization." <<
>> std::endl << std::endl ;
>>                 std::cout.flush() ;
>>         #endif
>>         #ifdef ENABLE_FTPD
>>                 std::cout << "  Starting  : FTP
>>Initialization..." <<
>> std::endl ;
>>                 std::cout.flush() ;
>>           rtems_initialize_ftpd();
>>                 std::cout << "  Completed : FTP
>>Initialization." <<
>> std::endl ;
>>                 std::cout.flush() ;
>>                 unsigned long temp = (unsigned
>>long)&TARFILE_SIZE ;
>>           status = Untar_FromMemory((unsigned char
>>*)(&TARFILE_START),
>> temp);
>>         #endif
>>         #ifdef ENABLE_WEB_SERVER
>>                 std::cout << "  Starting  : Webserver
>>Initialization..."
>> << std::endl ;
>>                 std::cout.flush() ;
>>           rtems_initialize_webserver();
>>                 std::cout << "  Completed : Webserver
>>Initialization."
>> << std::endl ;
>>                 std::cout.flush() ;
>>         #endif
>>         #ifdef ENABLE_TELNETD_SERVER
>>                 int rtems_initialize_telnetd ( void ) ;
>>                 std::cout << "  Starting  : Telnet
>> std::endl ;
>>                 std::cout.flush() ;
>>           rtems_initialize_telnetd();
>>                 std::cout << "  Completed : Telnet
>>Initialization." <<
>> std::endl ;
>>                 std::cout.flush() ;
>>         #endif
>> I can find the source for rtems_initialize_telnetd  in
>>the source tree
>> but when I try to build I get the following error :
>> C++ compiling /tcb2/source/BuildDateTime.cc...
>> Creating tcb2-debug.elf (linking)...
>> ConfigureNetwork.o: In function `ConfigureNetwork()':
>> ConfigureNetwork.o(.text+0x654): undefined reference to
>> `rtems_initialize_telnet
>> d()'
>> collect2: ld returned 1 exit status
>> make[1]: *** [tcb2-debug.elf] Error 1
>> make: *** [build] Error 2
>> It appears that telnetd is not included in the rtems
>>build but I can't
>> figure out how to get it included.
>> Any ideas?
> None here.  I just checked some build logs on the 4.6
>tree and
> telnetd.c is definitely being compiled.  The call is
>there.
> Can you do something like this?
> XXX-rtems-nm --extern-only .../librtemsbsp.a | grep
>telnet
> /opt/rtems-4.6/bin/mips-rtems-nm --extern-only
>/opt/rtems-4.6/mips-rtems/jmr3904/lib/librtemsbsp.a |
>grep telnet
> telnetd.o:
> 000002a0 T main_telnetd
> 00000374 T register_telnetd
> 000001b8 T rtems_initialize_telnetd
> 00000000 T rtems_task_telnetd
> 00000004 D telnetd_stack_size
> 00000000 D telnetd_task_id
> 00000008 D telnetd_task_priority
> So that symbol is definitely in the mips/jmr3904 I had
>installed.
>> Steve Holle
>> Link Communications, Inc.
>> 1035 Cerise Rd.
>> Billings, MT  59101
>> sholle at link-comm.com
> Joel Sherrill, Ph.D.             Director of Research &
>Development
> joel at OARcorp.com                 On-Line Applications
>Research
>    Support Available             (256) 722-9985
51, Le clos des G?ts
Rue de la gare
69730 Genay
France
EMAIL: correo At fernando-ruiz Dot com
