telnetd
Ralf Corsepius ralf_corsepius at rtems.org
Tue Sep 21 04:05:56 UTC 2004
> >>> I have a modified version of telnetd with a few enhancements.
> >>> Since it also supports being built as a loadable  module, it is
> >>> easy to find out how to initialize it (init done transparently when
> >>> loaded as a module). Just look at the 'cexpModuleInitialize()'
> >>> routines...
> >>> www.http://www.slac.stanford.edu/~strauman/rtems/telnetd/index.html
> >> Till.. is it OK to put this code in the RTEMS CVS?
> > Sure - how do we handle the CEXP dependencies, however?
What is CEXP?
> > Weak linker alias (thought they were not supported on all
> > RTEMS targets)? I'd be unhappy to continue supporting a separate
> > version if my changes make it into the 'official' distribution,
> > of course...
Standard answering template (weak linkage): Conditional compilation.
The configure scripts are able to check whether a tool chain supports
weak linkage (We already do). We can then disable compilation of the
code that depends on weak linkage, i.e. conditionally make a feature
unavailable.
> Thinking out loud for a minute .. Ralf can slap me if this
> is not a good answer.
> Since this requires networking and cexp requires
> networking, that already assumes a lot on a target.  Do all
> targets we want to support networking on already support weak
> linker aliases?
In general: no, de-facto: yes.
ATM, "weak-linkage" in RTEMS is more or less tied to "using GCC w/ELF".
More accurately: All GCC/ELF based toolchains for RTEMS claim to support
weak linkage.
> Could RTEMS be conditionally built with an --enable-cexp option?
I would prefer to avoid this whenever possible - Adding further
configure options should stay means of last resort.
> Till if there any chance of getting NFS or your Synergy BSP merged?
Ralf
