telnetd
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Sep 21 13:14:21 UTC 2004
Ralf Corsepius wrote:
>>>>>I have a modified version of telnetd with a few enhancements.
>>>>>Since it also supports being built as a loadable  module, it is
>>>>>easy to find out how to initialize it (init done transparently when
>>>>>loaded as a module). Just look at the 'cexpModuleInitialize()'
>>>>>routines...
>>>>>www.http://www.slac.stanford.edu/~strauman/rtems/telnetd/index.html
>>>>Till.. is it OK to put this code in the RTEMS CVS?
>>>Sure - how do we handle the CEXP dependencies, however?
> What is CEXP?
Till's "C expression shell" which includes dynamic download
capability.  It is comparable to the boot ROMs used b
a popular commercial RTOS.  You can put it permanently
on a board and then incrementally load your application
on top of the RTEMS/driver base image.
I don't know
>>>Weak linker alias (thought they were not supported on all
>>>RTEMS targets)? I'd be unhappy to continue supporting a separate
>>>version if my changes make it into the 'official' distribution,
>>>of course...
> Standard answering template (weak linkage): Conditional compilation.
> The configure scripts are able to check whether a tool chain supports
> weak linkage (We already do). We can then disable compilation of the
> code that depends on weak linkage, i.e. conditionally make a feature
> unavailable.
Ralf.. would you please add this test to the CVS trunk?
Till.. could you submit a PR with the latest telnetd as you
want it submitted?  I will merge it with the cexp code
disabled if we beat Ralf (unlikely) :)
If Ralf beats his, he can just let us know what conditional
to test on.
>>Thinking out loud for a minute .. Ralf can slap me if this
>>is not a good answer.
>>Since this requires networking and cexp requires
>>networking, that already assumes a lot on a target.  Do all
>>targets we want to support networking on already support weak
>>linker aliases?
> In general: no, de-facto: yes.
> ATM, "weak-linkage" in RTEMS is more or less tied to "using GCC w/ELF".
> More accurately: All GCC/ELF based toolchains for RTEMS claim to support
> weak linkage.
>>Could RTEMS be conditionally built with an --enable-cexp option?
> I would prefer to avoid this whenever possible - Adding further
> configure options should stay means of last resort.
>>Till if there any chance of getting NFS or your Synergy BSP merged?
> Ralf
