cygwin build_alias issue
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Sep 1 21:19:30 UTC 2004
Ralf Corsepius wrote:
> On Wed, 2004-09-01 at 06:16, Chris Johns wrote:
> I still think it's more likely a "resources problem", because the bug
> doesn't seem to be deterministically.
This seems to make sense but I can't figure out how my load would
vary that much.  I generally launch the same stuff every morning
(VNC, email, browser).
Today I have tried it multiple times with the gen68360 and efi332.
It fails sometimes and works sometimes.  I was trying just now to
get you a sh -x log and it started working.  I will keep trying to
capture a failure.
Also I am on Win2K which would avoid the process/file limit issue
you mentioned but might have others.
> E.g.
> * Scott's reports show that this issue pops up at different places, i.e.
> at places where configure scripts that were reported to fail in previous
> configure runs, must have finished successfully.
> * Joel's remark (--enable-rtemsbsp=..) indicates that reducing the
> amount of required resources, reduces the likelihood to trip this issue.
> So, I am inclined to think, that it's likely expr returning a bogus
> return value to be the trigger for these failures, but I doubt this is
> the origin.
> Ralf
