rtems_clock_get question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Thu Sep 9 18:31:22 UTC 2004
Etienne Fortin wrote:
> Let's say I don't have any clock driver, no hardware timer to create the
> clock tick. What happen when I call the rtems_clock_get() function? What
> value do I get? Can I assume that besided the
> RTEMS_CLOCK_GET_TICKS_PER_SECOND option that should not return zero,
> every other query with rtems_clock_get() return a value of zero???
The source is in cpukit/rtems/src/clockget.c :)
You will get a "never set" error when obtaining the time in native or
POSIX format as well as asking for seconds since epoch.
TIcks since boot will always return 0.
Ticks per second will return whatever you configured.
You can't timeout on anything or delay.
> Etienne Fortin
> Sensio
joel at OARcorp.com On-Line Applications Research
