powerpc/helas403 linkcmd question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Sep 10 17:29:06 UTC 2004
Smith, Gene wrote:
> Hi Thomas,
> Thanks for the quick answer!
> Since I have your ear, maybe you can answer another question regarding
> the ppc4xx startup code. In both helas and gen405 in file dlentry.S
> right before calling boot_card they set the stack pointer with an offset
> of -56-4 while the helas flashentry uses just -56. What is the
> significance of the -4 in the dlentry's? The comments don't explain the
> -4 (or lack of -4 in flashentry for helas). Also, I assume the 56 is a
> stack framesize? (I am just now learning about this ppc thing. :) )
Just to be a little begging... it really would be nice to get the
4xx PowerPCs converted over to the new interrupt model.
That would only leave a few 60x BSPs left on the old exception
model to deal with and then the old model could die.
--joel
> -gene
> Thomas Doerfler wrote, On 9/9/2004 11:00 AM:
>> Hello Gene,
>> hmmm, I should know that because I adapted the ppc403 support to my
>> helas403 board, but actually... I have no idea.
>> I guess, I used the first 64kByte for a debug monitor and therefore
>> relocated the vectors a bit up in the memory map. The PPC4xx family
>> has the ability to relocate the vectors on any 64k boundary.
>> I don't see any reason to leave it there, so feel free to remove the
>> ".fill" section. Just make sure you move the ".vectors" section by 64k.
>> wkr,
>> Thomas.
>>> I was wondering if anyone knows why the helas403 bsp linkcmds skips
>>> over the beginning 64k of ram before locating the vectors section at
>>> 0x00010100? It says it is "IMPORTANT" but not why. Is this just
>>> something specific about the helas403 board? I plan to just locate my
>>> 405gpr vectors section at 0x00000100 like the gen405 seems to do.
>>> Thanks,
>>> -gene
>> IMD Ingenieurbuero fuer Microcomputertechnik
>> Thomas Doerfler Herbststrasse 8
>> D-82178 Puchheim Germany
>> email: Thomas.Doerfler at imd-systems.de
>> PGP public key available at: http://www.imd-
>> systems.de/pgp_keys.htm
joel at OARcorp.com On-Line Applications Research
