telnetd
Till Straumann strauman at slac.stanford.edu
Mon Sep 20 21:17:44 UTC 2004
Joel Sherrill  wrote:
> Till Straumann wrote:
>> I have a modified version of telnetd with a few enhancements.
>> Since it also supports being built as a loadable  module, it is
>> easy to find out how to initialize it (init done transparently when
>> loaded as a module). Just look at the 'cexpModuleInitialize()'
>> routines...
>> www.http://www.slac.stanford.edu/~strauman/rtems/telnetd/index.html
> Till.. is it OK to put this code in the RTEMS CVS?
Sure - how do we handle the CEXP dependencies, however?
Weak linker alias (thought they were not supported on all
RTEMS targets)? I'd be unhappy to continue supporting a separate
version if my changes make it into the 'official' distribution,
of course...
-- T.
> --joel
>> HTH
>> -- Till
>> Steve Holle wrote:
>>> I've been doing some tracing with the debugger and apparently I need
>>> to initialize the pty terminals.  That seems to be where the telnet
>>> socket is closing down.  How do I initialize those?
>>> At 09:02 AM 9/20/2004, Steve Holle wrote:
>>>> This is a real bush league question but that's my style.
>>>> I have telnetd running, now how do I use it?  I've tried connecting
>>>> to both ports 24742 and 24743 with no luck.  When I try connecting
>>>> to port 23 I get "Connection to host lost." almost immediately.
>>>> Do I have to provide some kind of handler?
>>>> Thanks.
>>>> Steve Holle
>>>> Link Communications, Inc.
>>>> 1035 Cerise Rd.
>>>> Billings, MT  59101
>>>> sholle at link-comm.com
>>> Steve Holle
>>> 1035 Cerise Rd.
>>> Billings, MT  59101
