telnetd
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Sep 20 21:46:50 UTC 2004
Till Straumann wrote:
>>> I have a modified version of telnetd with a few enhancements.
>>> Since it also supports being built as a loadable  module, it is
>>> easy to find out how to initialize it (init done transparently when
>>> loaded as a module). Just look at the 'cexpModuleInitialize()'
>>> routines...
>>> www.http://www.slac.stanford.edu/~strauman/rtems/telnetd/index.html
>> Till.. is it OK to put this code in the RTEMS CVS?
> Sure - how do we handle the CEXP dependencies, however?
> Weak linker alias (thought they were not supported on all
> RTEMS targets)? I'd be unhappy to continue supporting a separate
> version if my changes make it into the 'official' distribution,
> of course...
Thinking out loud for a minute .. Ralf can slap me if this
is not a good answer.
Since this requires networking and cexp requires
networking, that already assumes a lot on a target.  Do all
targets we want to support networking on already support weak
linker aliases?
Could RTEMS be conditionally built with an --enable-cexp option?
Till if there any chance of getting NFS or your Synergy BSP merged?
> -- T.
>> --joel
>>> HTH
>>> -- Till
>>> Steve Holle wrote:
>>>> I've been doing some tracing with the debugger and apparently I need
>>>> to initialize the pty terminals.  That seems to be where the telnet
>>>> socket is closing down.  How do I initialize those?
>>>> At 09:02 AM 9/20/2004, Steve Holle wrote:
>>>>> This is a real bush league question but that's my style.
>>>>> I have telnetd running, now how do I use it?  I've tried connecting
>>>>> to both ports 24742 and 24743 with no luck.  When I try connecting
>>>>> to port 23 I get "Connection to host lost." almost immediately.
>>>>> Do I have to provide some kind of handler?
>>>>> Thanks.
>>>>> Steve Holle
>>>>> Link Communications, Inc.
>>>>> 1035 Cerise Rd.
>>>>> Billings, MT  59101
>>>>> sholle at link-comm.com
>>>> Steve Holle
>>>> 1035 Cerise Rd.
>>>> Billings, MT  59101
