Ada Language Support in sparc-rtems-gdb
Ralf Corsepius
ralf_corsepius at rtems.org
Wed Sep 22 08:02:21 UTC 2004
On Wed, 2004-09-22 at 08:31, Gert Caspersen wrote:
> I am using the GNAT Ada compiler distributed as part of RTEMS 4.6.1.
> However, I have discovered that the enclosed GNU debugger does not support
> the Ada language (i.e. using the 'set language' command).
> Is this to be expected, or have I made a blunder somewhere?
Welcome to the bleeding edge!
FSF/GNAT in general is in poor shape (newer versions aren't even
buildable) and so is Ada support in RTEMS.
So if you should have managed to *run* any RTEMS Ada code you're
probably further than anybody else on this planet ;)
Ralf
