PowerPC Burst PCI access
Till Straumann strauman at slac.stanford.edu
Fri Apr 8 01:39:44 UTC 2005
Peter Dufault wrote:
> These comments relate to the MVME5500 VME powerPC port and a PCI data
> acquisition card.
> In my control application I noticed a while ago that reading back the
> data from the PCI data acquisition board is extremely slow.  The board
> (acromag PMC341) collects the data into a pre-fetchable memory buffer
> that it says will transfer data at 40 MByte/s using burst reads.  I'm
> seeing about 4 MByte/s using naive reads and I eventually need to
> solve this problem.
That seems awfully slow. However, I can confirm that this matches what I
observe when I do PIO
to my PMC card mentioned below (I can only do 16-bit PIO, though).
When I use DMA the throughput is significantly better. I observe
latencies of 25us avg. and 45us worst case
for transferring 512 bytes [latency measures setting-up DMA, actual data
xfer, dispatching of 'dma done' ISR].
> With a 20KHz control loop I'm losing about 1/4 of the CPU using naive
> reads.
So the memory is on the PMC card - it's not that the PMC can DMA data
over to memory on the MVME5500,
right?
> As I understand it, if the memory region that the PowerPC fetches from
> is cacheable then the PowerPC will attempt to burst cache-line size
> reads.   I think the mapping from PowerPC to DAQ card is first through
> the PowerPC BAT registers and then a PCI window.
Hmm - I suspect the PCI memory is mapped non-cacheable. Don't know if
it's safe to make it cachable (does the PCI bus + the MVME5500's PCI
bridge implement coherency?). You have to be careful to avoid having
stale data in the cache.
Anyways, probably the best solution would be using DMA (don't know if
the MVME5500 has a DMA controller).
Otherwise, you could try to use e.g., a page table entry (or a spare
BAT) to map that special region cacheable
and then use 'dcbi' prior to each new transfer.
Sidenote: look at the PMC16AI64SS by generalstandards.com -- 64 x 16bit
@ 100kHz on a PMC module
with a fifo + DMA controller. A really nice card and less $/channel, it
seems.
> Is my understanding about right?  Is there some code I should look at
> as an example?
> I also tried fetching the memory as a "long double" but I started
> getting exceptions in my tasks. I assume my ISR started using floating
> point resources during the copy which caused this, so I also need a
> pointer to a method of doing cache-line size memory fetches without
> affecting the floating point state.
Bad - you *must not* use the FPU from an ISR. Results in FPreg
corruption - I just filed a PR today
regarding this...
HTH
-- Till
> Thanks,
> Peter
> Peter Dufault
> HD Associates, Inc.
