PowerPC Burst PCI access
Peter Dufault
dufault at hda.com
Fri Apr 8 08:44:40 UTC 2005
On Apr 7, 2005, at 9:39 PM, Till Straumann wrote:
> Peter Dufault wrote:
>> These comments relate to the MVME5500 VME powerPC port and a PCI data
>> acquisition card.
>> In my control application I noticed a while ago that reading back the
>> data from the PCI data acquisition board is extremely slow. The
>> board (acromag PMC341) collects the data into a pre-fetchable memory
>> buffer that it says will transfer data at 40 MByte/s using burst
>> reads. I'm seeing about 4 MByte/s using naive reads and I eventually
>> need to solve this problem.
> That seems awfully slow. However, I can confirm that this matches what
> I observe when I do PIO
> to my PMC card mentioned below (I can only do 16-bit PIO, though).
I'm toggling a TTL line around the copy and looking at a scope so that
is the rate. The time doesn't change when I go from 32 to 64 bit
transfers but that is to be expected, the pmc341 only does 32 bit
transfers. I'm pretty sure it did change when I went to the 128 bit
transfers but then I got the FP errors. I didn't look long, though, my
program went into emergency stop which took my attention away from the
scope, so maybe I imagined it was faster.
> When I use DMA the throughput is significantly better. I observe
> latencies of 25us avg. and 45us worst case
> for transferring 512 bytes [latency measures setting-up DMA, actual
> data xfer, dispatching of 'dma done' ISR].
>> With a 20KHz control loop I'm losing about 1/4 of the CPU using naive
>> reads.
> So the memory is on the PMC card - it's not that the PMC can DMA data
> over to memory on the MVME5500,
> right?
Correct.
>> As I understand it, if the memory region that the PowerPC fetches
>> from is cacheable then the PowerPC will attempt to burst cache-line
>> size reads. I think the mapping from PowerPC to DAQ card is first
>> through the PowerPC BAT registers and then a PCI window.
> Hmm - I suspect the PCI memory is mapped non-cacheable. Don't know if
> it's safe to make it cachable (does the PCI bus + the MVME5500's PCI
> bridge implement coherency?). You have to be careful to avoid having
> stale data in the cache.
The bridge is the GT64260 bridge, the same one that the system ethernet
is through, so I assume it does.
Then I think it is through a BAT to the system. I'll have to double
check.
> Anyways, probably the best solution would be using DMA (don't know if
> the MVME5500 has a DMA controller).
It might, but if it does it's on the NDA GT64260.
> Otherwise, you could try to use e.g., a page table entry (or a spare
> BAT) to map that special region cacheable
> and then use 'dcbi' prior to each new transfer.
That's what I was thinking. I have spare BATs since there are 8 on the
7450.
> Sidenote: look at the PMC16AI64SS by generalstandards.com -- 64 x
> 16bit @ 100kHz on a PMC module
> with a fifo + DMA controller. A really nice card and less $/channel,
> it seems.
>> Is my understanding about right? Is there some code I should look at
>> as an example?
>> I also tried fetching the memory as a "long double" but I started
>> getting exceptions in my tasks. I assume my ISR started using
>> floating point resources during the copy which caused this, so I also
>> need a pointer to a method of doing cache-line size memory fetches
>> without affecting the floating point state.
> Bad - you *must not* use the FPU from an ISR. Results in FPreg
> corruption - I just filed a PR today
> regarding this...
As I said, I wasn't sure the fetches would use the FPU. I already keep
my ISR in a separate file to generate errors by undefining sem_wait,
printf, etc at compile time, it would be nice to have a "generate error
on FPU access" compiler switch instead of a "soft FPU" compiler switch.
Peter Dufault
HD Associates, Inc.
