Rtems id question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Apr 18 13:54:28 UTC 2005
Manuel Pedro Coutinho wrote:
> Hi
> I'm trying to use the partition and rate monotonic managers on different
> tasks and I can't make them work properly
> If I do (for the rate monotonic example)
> Init(...)
> /* Task Start */
> status = rtems_task_create( rtems_build_name( 'T', 'A', '1', ' ' ), 10,
> RTEMS_MINIMUM_STACK_SIZE , RTEMS_DEFAULT_MODES,
> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id1);
> status = rtems_task_create( rtems_build_name( 'T', 'A', '2', ' ' ), 20,
> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id2);
> status = rtems_task_create( rtems_build_name( 'T', 'A', '3', ' ' ), 30,
> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id3);
> /* Rate monotonic Create*/
> rtems_rate_monotonic_create(rtems_build_name( 'R' , 'T' , 'A' ,
> '1'),&period1);
> '2'),&period2);
> '3'),&period3);
> /* Rate monotonic start */
> rtems_rate_monotonic_period(periodo1,100);
> rtems_rate_monotonic_period(periodo2,200);
> rtems_rate_monotonic_period(periodo3,300);
> /* Task Start */
> status = rtems_task_start( id3, Task3 , 0 );
> status = rtems_task_start( id2, Task2 , 0 );
> status = rtems_task_start( id1, Task1 , 0 );
> and then on each task do something like:
> rtems_task Task1(rtems_task_argument arg)
> rtems_rate_monotonic_period_status status;
> rtems_id period1;
> rtems_status_code stat;
> stat = rtems_rate_monotonic_ident( rtems_build_name('R' , 'T' , 'A' ,
> '1' ) , &period1);
> if( stat != RTEMS_SUCCESSFUL )
> fatal_error("error\n");
> while(1)
> /* PERFORM TASK1 */
> /* Wait for end of period */
> if(rtems_rate_monotonic_period(period1,100) == RTEMS_TIMEOUT)
> fatal_error("error!");
> This task can't increment the tick count and stays blocked in the
> rate_monotonic_period, but
> the RTEMS functions don't return error. The system.h is defined as follows
> #define CONFIGURE_MAXIMUM_TASKS 10
> #define CONFIGURE_MICROSECONDS_PER_TICK 100000/2
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_PERIODS 30
> #define CONFIGURE_INIT
> #define CONFIGURE_INIT_TASK_PRIORITY 1
> #include <confdefs.h>
> if the rate monotonic is built on each task seperatly, the system works
> so I guess this isn't a problem of bad configuration.
> Also, if instead of each searching for the rate monotonic name, it uses
> its global id variable, the result is the same: the tick variable
> doesn't change.
The periods are supposed to be started in the task that uses them.
There is bookkeeping assocated with a task if I remember right and
by starting it in another task, you may be messing that up.
> A similar error comes when I use the partition: It's created during
> driver initialization and when used on a task (using its global id), the
> partition_get function doesn't return an error but something "stupid"
> happens: I do the following
> rtems_partition_get( partition_id, &pointer );
> pointer->some_field = 10;
> and when I print the pointer->some_field, it always returns 255, no
> matter of what I try to put there! (by the way, the pointer->some_field
> is an unsigned char)
Are you sure the managers are in the executable?
Are you declaring the appropriate variables as global? If they are on
the stack, they are private to a task and will disappear entirely when
something falls otu of scope.
> Can anyone tell me what I'm doing wrong? I'm sure this must be something
> very simple to workout, but I can't manage to figure this one out!
> Many Thanks
> Manuel Coutinho
> _________________________________________________________________
> MSN Hotmail, o maior webmail do Brasil. http://www.hotmail.com
joel at OARcorp.com On-Line Applications Research
