Rtems id question
Manuel Pedro Coutinho
manuelpedrocoutinho at hotmail.com
Mon Apr 18 15:23:07 UTC 2005
>From: "Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com>
>Reply-To: joel.sherrill at OARcorp.com
>To: Manuel Pedro Coutinho <manuelpedrocoutinho at hotmail.com>
>CC: rtems-users at rtems.com
>Subject: Re: Rtems id question
>Date: Mon, 18 Apr 2005 08:54:28 -0500
>Manuel Pedro Coutinho wrote:
>>Hi
>>I'm trying to use the partition and rate monotonic managers on different
>>tasks and I can't make them work properly
>>If I do (for the rate monotonic example)
>>Init(...)
>> /* Task Start */
>> status = rtems_task_create( rtems_build_name( 'T', 'A', '1', ' ' ),
>>10,
>> RTEMS_MINIMUM_STACK_SIZE , RTEMS_DEFAULT_MODES,
>> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id1);
>> status = rtems_task_create( rtems_build_name( 'T', 'A', '2', ' ' ),
>>20,
>> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id2);
>> status = rtems_task_create( rtems_build_name( 'T', 'A', '3', ' ' ),
>>30,
>> RTEMS_FLOATING_POINT | RTEMS_GLOBAL, &id3);
>> /* Rate monotonic Create*/
>> rtems_rate_monotonic_create(rtems_build_name( 'R' , 'T' , 'A' ,
>>'1'),&period1);
>>'2'),&period2);
>>'3'),&period3);
>> /* Rate monotonic start */
>> rtems_rate_monotonic_period(periodo1,100);
>> rtems_rate_monotonic_period(periodo2,200);
>> rtems_rate_monotonic_period(periodo3,300);
>> /* Task Start */
>> status = rtems_task_start( id3, Task3 , 0 );
>> status = rtems_task_start( id2, Task2 , 0 );
>> status = rtems_task_start( id1, Task1 , 0 );
>>and then on each task do something like:
>>rtems_task Task1(rtems_task_argument arg)
>> rtems_rate_monotonic_period_status status;
>> rtems_id period1;
>> rtems_status_code stat;
>> stat = rtems_rate_monotonic_ident( rtems_build_name('R' , 'T' , 'A' ,
>>'1' ) , &period1);
>> if( stat != RTEMS_SUCCESSFUL )
>> fatal_error("error\n");
>> while(1)
>> /* PERFORM TASK1 */
>> /* Wait for end of period */
>> if(rtems_rate_monotonic_period(period1,100) == RTEMS_TIMEOUT)
>> fatal_error("error!");
>>This task can't increment the tick count and stays blocked in the
>>rate_monotonic_period, but
>>the RTEMS functions don't return error. The system.h is defined as follows
>>#define CONFIGURE_MAXIMUM_TASKS 10
>>#define CONFIGURE_MICROSECONDS_PER_TICK 100000/2
>>#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
>>#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
>>#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>#define CONFIGURE_MAXIMUM_PERIODS 30
>>#define CONFIGURE_INIT
>>#define CONFIGURE_INIT_TASK_PRIORITY 1
>>#include <confdefs.h>
>>if the rate monotonic is built on each task seperatly, the system works so
>>I guess this isn't a problem of bad configuration.
>>Also, if instead of each searching for the rate monotonic name, it uses
>>its global id variable, the result is the same: the tick variable doesn't
>>change.
>The periods are supposed to be started in the task that uses them.
>There is bookkeeping assocated with a task if I remember right and
>by starting it in another task, you may be messing that up.
>>A similar error comes when I use the partition: It's created during driver
>>initialization and when used on a task (using its global id), the
>>partition_get function doesn't return an error but something "stupid"
>>happens: I do the following
>> rtems_partition_get( partition_id, &pointer );
>> pointer->some_field = 10;
>>and when I print the pointer->some_field, it always returns 255, no matter
>>of what I try to put there! (by the way, the pointer->some_field is an
>>unsigned char)
>Are you sure the managers are in the executable?
>Are you declaring the appropriate variables as global? If they are on the
>stack, they are private to a task and will disappear entirely when
>something falls otu of scope.
(First of all, I apologize for sending this mail twice to joel sherrill)
The managers are indeed in the executable (at least the application Makefile
has Managers = all)
Has to declaring the variables as global... I'm sorry for the dumb question,
but one has to do more than the following:
rtems_id global_id;
Init(...)
I thought that the problem was somehow related to the the task beeing
declared as global or local...
Thanks again!
Manuel Coutinho
>>Can anyone tell me what I'm doing wrong? I'm sure this must be something
>>very simple to workout, but I can't manage to figure this one out!
>>Many Thanks
>>Manuel Coutinho
>>_________________________________________________________________
>>MSN Hotmail, o maior webmail do Brasil. http://www.hotmail.com
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
