Filesystem vs malloc space
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Apr 26 18:42:27 UTC 2005
Thomas Doerfler wrote:
> Angelo Fraietta schrieb:
> I think you missinterprete the functionality of
> IMFS_memfile_maximum_size(): It does not return the amount of memory
> left for file creation, but returns a constant, that defines the maximum
> file size, that can be created using the IMFS, even if more memory would
> be available. In normal configurations, the size of each file is limited
> to 4MByte.
That's the answer. :)
The function exists because you can (at compile time) configure the
block size used by the IMFS. If you pick a small block size, you
get a smaller maximum file size. From cpukit/libfs/src/imfs/imfs.h
* IMFS "memfile" information
* The data structure for the in-memory "memfiles" is based on classic
UNIX.
* block_ptr is a pointer to a block of IMFS_MEMFILE_BYTES_PER_BLOCK in
* length which could be data or a table of pointers to blocks.
* Setting IMFS_MEMFILE_BYTES_PER_BLOCK to different values has a
significant
* impact on the maximum file size supported as well as the amount of
* memory wasted due to internal file fragmentation. The following
* is a list of maximum file sizes based on various settings
* max_filesize with blocks of 16 is 1,328
* max_filesize with blocks of 32 is 18,656
* max_filesize with blocks of 64 is 279,488
* max_filesize with blocks of 128 is 4,329,344
* max_filesize with blocks of 256 is 68,173,568
* max_filesize with blocks of 512 is 1,082,195,456
> wkr,
> Thomas.
>>Greetings all
>>I have found that I am running out of malloc memory on my system
>>By doing the following two calls, I can see how much memory I have
>> printf ("\r\nFree Space %u", malloc_free_space());
>> printf("\r\nMax Filesystem Size %u",
>>IMFS_memfile_maximum_size());
>>At first, I have approx 5527408 bytes of malloc memory and 4329344 bytes
>>of free filesystem space.
>>After loading a heap of data, I end up with approx 207000 bytes of
>>malloc memory left, buts still have the same amount of Filesystem space
>>left (this is strange as I have just downloaded nearly 100K of files to
>>my system). This 200K of malloc space that I have left is still not
>>enough to dod what I still have to do
>>How do I reduce the amount of filesystem space and increase the amount
>>of space for malloc?
>>Why didn't the Filesystem space show the difference; or is it that the
>>call I made shows the total IMFS space- not the amount remaining.
>>Thanks
joel at OARcorp.com On-Line Applications Research
