Can't use yum to get rpms
Sebastian Garcia @gmail
sebasgarcia at gmail.com
Sun Aug 21 22:05:48 UTC 2005
Hi,
I'm having this same problem (FC4 ; yum v. 2.3.2).
I'm not a yum expert, but it seems the repository was created with
yum-arch (or other old tool) that doesn't create the .xml metadata
files.
Is there a way to make yum desist looking for these files?
TIA,
Sebastian.-
== Sebastian E. Garcia ~ Desarrollo de electronica embebida
== sebasgarcia arroba gmail.com ~ 54.11.4833.4123 ~ Buenos Aires
On 6/13/05, Peter Dufault <dufault at hda.com> wrote:
> I'm trying to follow the directions at http://www.rtems.org/
> yum.html. When I issue the "yum" commands I get:
> "ftp://ftp.rtems.com/pub/rtems/linux/redhat/7.3/i386/rtems-4.6/
> repodata/repomd.xml: [Errno 4] IOError: [Errno ftp error] 550 Failed
> to change directory"
> and that directory does indeed not exist on the RTEMS server.
> What am I doing wrong?
> This is Fedora Core 3 on x86 and up-to-date, and yum --version says
> it is 2.2.20.
> Thanks -
> Peter
